Installation & Licensing
Problem running Mudbox 2014 installer
3 REPLIES 3
432 Views, 3 Replies
I keep getting the following error when I try running the installer setup.exe file.
3 REPLIES 3
DarrenP
try moving the windows temp back to default under the users folder
DarrenP
dembkod
landon_lo ,
Hello. Turn off your Antivirus before you install and make sure you are an Admin. You can move your temp directory as DarrenP suggested.
I have some steps for you to do this if you need them:
Windows 7 and XP:
1.)           Open a new, simple text file
2.)           Open windows explorer and create a new folder in the root of C:. Let’s call it "Test"
3.)           Right-click My Computer and click "Properties"
4.)           Click "Advanced system settings"
5.)           On the "Advanced" tab click "Environment Variables"
6.)           Double-click the TEMP variable and copy the value out into the new text file
7.)           Chance the value in the Variable to your new path
8.)           Click OK
9.)           Double-click the TMP variable and copy the value out into the new text file
10.)         Chance the value in the Variable to your new path
11.)         Click OK
After your test, use the copied paths in the new text file to return the variables to normal.
 Windows 8
3.)           Access the Metro Interface
4.)           Type "Variables" and press Enter
5.)           Click Settings
6.)           Click "Edit the system Environment Variables"
8.)           Click OK
11.)         Click OK
Thank you for taking part in our community!
David Dembkoski
in reply to: DarrenP
Moving my User Variable Temp folders back to their default directories worked. Thanks!
Administrator Productivity
