Installation & Licensing
1799 Views, 4 Replies
Mudbox 2014 Activation
I can't activate the Mudbox 2014 Education/Student Licence.
Screenshot attached.
- I uninstalled Mudbox and installed it.
- I used the reinstall function
- I used the repair function
- I have access to the ASR folder and there are files in it. (68 files)
(C:\ProgramData\Autodesk\Adlm\ASR)
- I also tried to deactivate the network to see if some manuall activation prompt appears, but still the same message.
It's a windows 7 x64
Tags (2)
4 REPLIES 4
TravisNave
Welcome to the community.
I would start by reading this entire thread:
http://forums.autodesk.com/t5/Installation-Licensing/Licensing-Error-Code-110-AutoCAD-and-Civil-3D-2...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
in reply to: TravisNave
Thanks for the link but there's no new solution.
1.       ASR folder was not created during the install.
2.       Missing ASR files from ASR folder.
I have an ASR folder and I have files in it. And I can access the folder.
I also tried the "Take Ownership" solution. I've took the ownership of the Autodesk folger and the FLEXNet folder.
And reinstalled Mudbox. But still the same problem.
Hi
I am getting the same issue and wondering what to do ? I have uninstalled and reinstalled but  no diffrence 😞
help !
dembkod
jakub.juszczak
Hello. I would uninstall, then delete that folder in the other post. Then delete the TSF.data file on your machine. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
Windows XP:
Documents and Settings\All Users\Application Data\FLEXnet
Vista/Windows 7:
C:\ProgramData\FLEXnet
After these are gone, install the program and try to activate.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
