Well, that was a good suggestion. I tried again during working hours.
At first it still didn't work. I checked the path to the licennse file on
the config services tab.
It was pathed correctly but I browsed out to the license file anyway to
reread it.
Doing that still did not fix it.
So, I went to t Server/License file tab and selected the Configuration using
License file button.
By doing this it does refrence the GSI_License_file. I browsed to my
license file but still no luck.
By chance I decided to check the box on the first tab that says
LMTOOLS ignores license file path environment
Bammo, one I check that box everything started working.
I hope there are no serious consequences of checking that box.
Thanks to everyone who contributed to this resolution.
Newsgoups Rock!!
Greg
"jerry milana (Autodesk Consulting)" wrote in message
news:4850155@discussion.autodesk.com...
Greg,
Are you sure that your license manager is configured to look at the correct
license file?
>>C:\Gsi\SAMreport\machind\license\license.dat<< looks more like your
>>SAMreport-Lite license. Try reconfiguring your service in LMtools and
>>make sure that you are pointing to the correct license file.
Jerry Milana,
Autodesk Consulting
"Greg" wrote in message
news:4848865@discussion.autodesk.com...
This is the file I already used as a reference when I started this process.
Going back to the original problem, Once the server was upgraded to 10.1.5
from the 2006 disk, it would not read the license file for 2004. The error
indicated that there was no server lines in license file.
greg
"Jimmy Bergmark" wrote in message
news:4848605@discussion.autodesk.com...
I have done it in the middle of the day:
http://jtbworld.blogspot.com/2005/04/upgrade-autodesk-network-license.html
Best Regards, Jimmy Bergmark
CAD and Database Developer Manager at www.pharmadule-emtunga.com
Blog: http://jtbworld.blogspot.com
JTB FlexReport (FLEXnet / FLEXlm report tool) -
http://www.jtbworld.com/jtbflexreport
SmartPurger (Purges automatically) -
http://www.jtbworld.com/?/smartpurger.htm
or download some freeware at http://www.jtbworld.com
More on AutoCAD 2005 and 2006
http://www.jtbworld.com/autocad2005.htm
http://www.jtbworld.com/autocad2006.htm
news:4848252@discussion.autodesk.com...
Even after hours we always have some people working. It makes it hard to do
the whole uninstall and reinstall process.
I guess if I want it to work then I will have to find a time when no one is
here.
"Jenna" wrote in message
news:4847410@discussion.autodesk.com...
I did the uninstall and reinstall after hours, but there was practically no
downtime to speak of. I did not have to reboot the server and the whole
process took maybe 15 minutes. It was very easy and as I recall had prompts
that stepped me through everything, but really kept all my existing settings
from the previous version with little to no effort on my part.
news:4846554@discussion.autodesk.com...
Thanks Jenna,
That was the original question I had when I started this process. I want to
use the same server and I don't to have significant downtime. It was
suggested that you could replace the 4 server files with the new ones from
the new disc.
Of course I had to stop the service etc. but if done quickly enough, no
down time. When all of that is done and the license file is re-read,
everything is supposed to work. However it does not work for me with the
2006 version.
So I guess the question still remains if there is something different with
the new version or old license files that cause this process not to work.
Greg
news:4846533@discussion.autodesk.com...
Did you actually uninstall the ANLM software and install the current version
from the 2006 disk? I just wonder if there may be other files/registry
entries that need to be updated besides the four FlexLM files.
news:4846324@discussion.autodesk.com...
That's what I thought too and I did everything by the book.
I tried my 2004 license file and I tried a 2005 license file.
Shut down the service and replace the 4 files, verified they were the 4 new
files.
restarted the server and reread the license file.
That is why I am baffled and wonder if there is something special with the
2006 version of the FlexLM.
news:4846316@discussion.autodesk.com...
You should be able to uninstall the old ANLM software (retaining your
existing lic file, of course), then install the new and direct it to the
existing license file. You can add your license information for 2006
directly to the existing license file with cut and paste.
news:4846180@discussion.autodesk.com...
I would like to upgrade our license servers to the latest version of FlexLM.
I intend to run 2005 for a while before upgrading to 2006 but would like to
upgrade the license server software to 2006 so I don't have to do it again
later. I have successfully upgraded my license files and the server
software to 2005, but I thought the 2006 version would read my 2005 license
files. However, when I use the method of replacing the 4 files as described
in previous posts I get an error that states
[Detecting lmgrd processes...]
Error getting status: No SERVER lines in license file.
License path: C:\Gsi\SAMreport\machind\license\license.dat
FLEXnet Licensing error:-13,66
I have checked the macrovision website and the Users Guide and have found
reference to this error, but it doesn't really tell me what it means or how
to solve it.
Is there something I am missing?
Thanks for the help
Greg
