I am having an issue where Maya decides to post up a GUI license error. And then gives this message to me
I do not know why, but I have tried to Uninstall and reinstall Maya, I have changed the FLEXnet Licensing Service to Automatic and started it, yet Maya still does not work. I have tried to change the .env file to 657F1, still does not work. I have tried deleting the little mysterious file with it's back up file, and it still has not worked. I need Maya for portfolio work, please help!
Solved by david.lau. Go to Solution.
Can you try to uninstall Maya and then install the free update? The Maya SP is a FULL installer.
http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9242259
I have the same problem. I install Maya 2015 and the first time I opened it it works pefect. But it was half installed. The next day I complete the installation and when I tried, there was
