Have installed Autocad 2011, but install in not placing main dictionary properly. Which effects spell check and I get an error message every time I edit any text.
Have repaired and reinstalled with no luck. Matter of fact, the last install left the "express" and "font" folders out.
Reinstall is having an error locating a "barlib7_bs.xml" file, but I can locate it under the program folder
Can anyone tell me what's going on?
Solved by Charles_Shade. Go to Solution.
Something in your system is impeaching AutoCAD 2011 to install correctly.
Please try the following:
SDI variable still there?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Please mark any response as "Accept as Solution" if it answers your question.
______________________________________________________________
I have been trying to edit scale of diagonal hatch that revit generates with in walls (little large). Is this possible?
Maybe try the Revit Structural Forum?:
http://forums.autodesk.com/t5/Autodesk-Revit-Structure/bd-p/153
