I have some trouble licensing Maya under Fedora!
First I tried following the Installation Guide. Then I got the Problem, that when I tried running maya I got the well know Error "License was not obtained".
After doing a lot of searchin on the web I found some commands I had to enter that brought so far that I was finally asked to get an activation code. I filled clicked through the pages and 3 temporary ESEC2010*.xml files were saved to my local temp file. Furthermore I got an eMail with another ESEC*.xml file.
Now I tried running maya again to tell it to use one of those... but now whenever I try running it I get this message:
maya encountered a fatal error
Signal: 11 (Unknown Signal)
I also found this command:
/usr/autodesk/maya2010-x64/bin/adlmreg -i S 656B1 656B1 2010.0.0.F <mySerial> /var/opt/Autodesk/Adlm/Maya2010/MayaConfig.pit
but all I get back is
Registration failed. Reasons: 13
Can someone guide me? What should I do with the XML files?
Please, please it's almost 3 am here and it's urgent that I get it up and running soon!
Thanks in advance!
--Markus
I also exported MAYA_DEBUG_ENABLE_CRASH_REPORTING=1
and if I now start maya, the output says:
~$ maya
Stack trace:
/lib64/libc.so.6() [0x38f7a34100]
TinputDeviceManager::deviceByIndex(short) const
Twindow::unStow(Tevent const&)
TstartupWnd::unStow(Tevent const&)
/usr/autodesk/maya2010-x64/bin/maya.bin() [0x413ead]
/usr/autodesk/maya2010-x64/bin/maya.bin() [0x411e32]
/usr/autodesk/maya2010-x64/bin/maya.bin() [0x40fbcf]
/usr/autodesk/maya2010-x64/bin/maya.bin() [0x41d88b]
__libc_start_main
Writing crash report in /usr/tmp/20110112.1408.crash
Does this tell anyone something?
Thank you!
