Solved by ukdxb012. Go to Solution.
Hi @Anonymous and welcome to the Autodesk Community!
Are you by chance seeing a specific error before the install windows closes? Have you tried changing your download method? The Browser Download method tends to work great. Please take the following precautions upon your next download attempt:
Please let us know if this helps! If not, please reply with your installation log file for further troubleshooting. We look forward to hearing from you. Thanks!
That did not work..
the log info I found is here..
18:30:01 | CBandToolBarCtrl::DownloadFiles - Lock ||
18:30:01 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
18:30:01 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
18:30:01 | CDriver::OpenDriverHandle, device: 212 ||
18:30:02 | CDriver::CloseDriverHandle, device: 212 ||
18:30:02 | CDriver::CloseDriverHandle, valid handle ||
18:30:02 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
18:30:02 | CDriver::OpenDriverHandle, device: 212 ||
18:30:02 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
18:30:02 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
18:30:02 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
18:30:02 | CProductManager: Created ||
18:30:02 | CRegistry::Init - folder is empty. failed to init. ||
18:30:02 | CRegistry::GetCommonName(): AVG Secure Search ||
18:30:02 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
18:30:02 | CINIReader::Init - init: 1 ||
18:30:02 | CINIReader::GetText - start ||
18:30:02 | CINIReader::GetText - sSection: InstalledProducts ||
18:30:02 | CINIReader::GetText - sParamName: vToolbarUpdater ||
18:30:02 | CINIReader::GetText - result: 18.1.9 ||
18:30:02 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
18:30:02 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
18:30:02 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
18:30:02 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
18:30:02 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
18:30:02 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
18:30:02 | CRegistry::getValue(...), for key: CurCmpId ||
18:30:02 | CRegistry::getValue(...), QueryStringValue error: 2 ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
18:30:02 | CSystemCommands::GetUserID, (zstring) - start ||
18:30:02 | CSystemCommands::GetSafeEnv, (zstring) - start ||
18:30:02 | CSystemCommands::GetSafeEnv - (bool) - start ||
18:30:02 | CSystemCommands::GetSafeEnv, varName: appdata ||
18:30:02 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
18:30:02 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
18:30:02 | CBandToolBarCtrl::DownloadImages start ||
18:30:03 | CSystemCommands::GetSafeEnv - (bool) - start ||
18:30:03 | CSystemCommands::GetSafeEnv, varName: appdata ||
18:30:03 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
18:30:03 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
18:30:03 | CRegistry::getValue(...), for key: CurCmpId ||
18:30:03 | CRegistry::getValue(...), QueryStringValue error: 2 ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
18:30:03 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
18:30:03 | CSystemCommands::GetUserID, (zstring) - start ||
18:30:03 | CSystemCommands::GetSafeEnv, (zstring) - start ||
18:30:03 | CBandToolBarCtrl::DownloadFiles - Unlock ||
20:13:28 | CBandToolBarCtrl::DownloadFiles - Lock ||
20:13:28 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:13:28 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:13:28 | CDriver::OpenDriverHandle, device: 212 ||
20:13:28 | CDriver::CloseDriverHandle, device: 212 ||
20:13:28 | CDriver::CloseDriverHandle, valid handle ||
20:13:28 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
20:13:28 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
20:13:28 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:13:28 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
20:13:28 | CProductManager: Created ||
20:13:28 | CRegistry::Init - folder is empty. failed to init. ||
20:13:28 | CRegistry::GetCommonName(): AVG Secure Search ||
20:13:28 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:13:28 | CINIReader::Init - init: 1 ||
20:13:28 | CINIReader::GetText - start ||
20:13:28 | CINIReader::GetText - sSection: InstalledProducts ||
20:13:28 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:13:28 | CINIReader::GetText - result: 18.1.9 ||
20:13:28 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:13:29 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
20:13:29 | CRegistry::Init - folder is empty. failed to init. ||
20:13:29 | CRegistry::GetCommonName(): AVG Secure Search ||
20:13:29 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:13:29 | CINIReader::Init - init: 1 ||
20:13:29 | CINIReader::GetText - start ||
20:13:29 | CINIReader::GetText - sSection: InstalledProducts ||
20:13:29 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:13:29 | CINIReader::GetText - result: 18.1.9 ||
20:13:29 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:13:33 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:13:34 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
20:13:35 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:13:35 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:35 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:13:35 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:13:35 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
20:13:35 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:13:35 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:36 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:13:36 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
20:13:36 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:13:36 | CProductManager: Created ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:13:36 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
20:13:36 | CRegistry::getValue(...), for key: CurCmpId ||
20:13:36 | CRegistry::getValue(...), QueryStringValue error: 2 ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
20:13:36 | CSystemCommands::GetUserID, (zstring) - start ||
20:13:36 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:13:36 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:13:36 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:13:36 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:13:36 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:13:36 | CBandToolBarCtrl::DownloadImages start ||
20:13:37 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:13:37 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:13:37 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:13:37 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:13:37 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:13:37 | CRegistry::getValue(...), for key: CurCmpId ||
20:13:37 | CRegistry::getValue(...), QueryStringValue error: 2 ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:13:37 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
20:13:37 | CSystemCommands::GetUserID, (zstring) - start ||
20:13:37 | CBandToolBarCtrl::DownloadFiles - Unlock ||
20:22:21 | CSystemCommands::GetUserID, (zstring) - start ||
20:22:24 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:22:24 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:22:24 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:22:24 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:22:24 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:22:24 | vprot.exe - _tWinMain, creating mutex.: Local\vprotector19355017207497b4 ||
20:22:24 | AVInfo: AVInfo C'tor, start ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2014 ||
20:22:24 | CRegistry::IsKeyExists(), Open error: 2 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2013 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2012 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg10 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg9 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg8 ||
20:22:24 | CRegistry::Init - folder is empty. failed to init. ||
20:22:24 | CCrashReport::CCrashReport() no AV installed/AV version isn't 2014 ||
20:22:24 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:24 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
20:22:24 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:24 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:24 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
20:22:24 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:26 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:22:27 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
20:22:27 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:27 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
20:22:27 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:22:27 | CProductManager: Created ||
20:22:27 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:22:27 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:28 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:22:28 | CINIReader::Init - init: 1 ||
20:22:28 | CINIReader::GetText - start ||
20:22:28 | CINIReader::GetText - sSection: InstalledProducts ||
20:22:28 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:22:28 | CINIReader::GetText - result: 18.1.9 ||
20:22:28 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:28 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:28 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
20:22:28 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:22:28 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:29 | CBandToolBarCtrl::DownloadFiles - Lock ||
20:22:29 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:29 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:22:30 | CDriver::OpenDriverHandle, device: 204 ||
20:22:30 | CDriver::CloseDriverHandle, device: 204 ||
20:22:30 | CDriver::CloseDriverHandle, valid handle ||
20:22:30 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
20:22:30 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
20:22:30 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:30 | CSystemCommands::GetCommonFilePath - ProductVersion: ||
20:22:30 | CProductManager: Created ||
20:22:30 | CRegistry::Init - folder is empty. failed to init. ||
20:22:30 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:30 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:22:30 | CINIReader::Init - init: 1 ||
20:22:30 | CINIReader::GetText - start ||
20:22:30 | CINIReader::GetText - sSection: InstalledProducts ||
20:22:30 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:22:30 | CINIReader::GetText - result: 18.1.9 ||
20:22:30 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:31 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:22:31 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
20:22:31 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:22:31 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:31 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:31 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
I can download the program fine, but when it comes up to install I immediately get an error, here is the picture of the erro
Sorry to say that your attachment is quite small / blurry and I cannot read it. If you could please reply with an attachment of your installation log file for further troubleshooting it would be very helpful. Thanks!
the log will not post on this feed ive copied it in the reply and posted it many times and it keeps dissapearing
2014/9/16:21:15:18 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_Architecture_2014_English_Win_32-64bit_dlm
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Launch
2014/9/16:21:15:18 House Computer HOUSECOMPUTER CommandLine
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI9740.tmp
2014/9/16:21:21:23 House Computer HOUSECOMPUTER === Setup ended ===
2014/9/16:21:26:36 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_Architecture_2014_English_Win_32-64bit_dlm
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Launch
2014/9/16:21:26:36 House Computer HOUSECOMPUTER CommandLine
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AIF1ED.tmp
2014/9/16:21:26:48 House Computer HOUSECOMPUTER === Setup ended ===
"2014/9/16:21:15:18 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:26:48 House Computer HOUSECOMPUTER === Setup ended ==="
Hi @Anonymous,
Could you try just copying the last paragraph? Have you tried posting it to a word document first and attaching that file?
Hopefully this works as a word file!
Hi @Anonymous,
The attachment worked but there isn't an error listed in what you've provided. Since we know a word document attachment works, please post the entire log. Thanks for hanging in there!
That is the entire log for the installation... I will also attatch the toolbar log? thats the only other log that comes up. I am also trying again to attatch the error message to you. Maybe it does not show up in the log because it is not a download issue but an installation issue?
2014/9/17:11:48:29 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:11:48:29 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/17:11:48:29 House Computer HOUSECOMPUTER Current Directory C:\Program Files\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:11:48:29 House Computer HOUSECOMPUTER Launch
2014/9/17:11:48:29 House Computer HOUSECOMPUTER CommandLine
2014/9/17:11:48:30 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/17:11:48:30 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI399.tmp
2014/9/17:12:02:39 House Computer HOUSECOMPUTER === Setup ended ===
2014/9/17:14:20:25 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:14:20:25 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/17:14:20:25 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:14:20:25 House Computer HOUSECOMPUTER Launch
2014/9/17:14:20:25 House Computer HOUSECOMPUTER CommandLine
2014/9/17:14:20:25 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI18F0.tmp
2014/9/17:14:20:39 House Computer HOUSECOMPUTER === Setup ended ===
2014/9/17:15:08:27 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:15:08:27 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/17:15:08:27 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:15:08:27 House Computer HOUSECOMPUTER Launch
2014/9/17:15:08:27 House Computer HOUSECOMPUTER CommandLine
2014/9/17:15:08:27 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI1845.tmp
2014/9/17:15:08:35 House Computer HOUSECOMPUTER === Setup ended ===
2014/9/17:18:33:36 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:18:33:36 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/17:18:33:36 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:18:33:36 House Computer HOUSECOMPUTER Launch
2014/9/17:18:33:36 House Computer HOUSECOMPUTER CommandLine
2014/9/17:18:33:36 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AIE8B1.tmp
2014/9/17:18:44:29 House Computer HOUSECOMPUTER === Setup ended ===
