Installation & Licensing
Message 1 of 24
laurenm9
863 Views, 23 Replies
Install error
I have downloaded revit 2014 all possible ways, even on another computer and brought the file over) when the product pulls up the installer an error instantly pops up and closes down the installation . I have also deleted my temp file folder . Any advise?
23 REPLIES 23
Message 2 of 24
jessica.t
in reply to: laurenm9
Hi @laurenm9 and welcome to the Autodesk Community!
Are you by chance seeing a specific error before the install windows closes? Have you tried changing your download method? The Browser Download method tends to work great. Please take the following precautions upon your next download attempt:
  • In the preferences or options area of your preferred browser, remove pop-up blockers and allow access to all *autodesk.com sites.
  • In the preferences or options area of your preferred browser, delete cookies, temporary internet files, and history.
  • Turn off your personal firewall or VPN, if you use one.
  • Disable UAC
  • Close and reopen your preferred browser.
  • Re-download from the Virtual Agent
Please let us know if this helps! If not, please reply with your installation log file for further troubleshooting. We look forward to hearing from you. Thanks!
Jessica Thrasher
Message 3 of 24
laurenm9
in reply to: jessica.t
That did not work..
the log info I found is here..
18:30:01 | CBandToolBarCtrl::DownloadFiles - Lock ||
18:30:01 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
18:30:01 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
18:30:01 | CDriver::OpenDriverHandle, device: 212 ||
18:30:02 | CDriver::CloseDriverHandle, device: 212 ||
18:30:02 | CDriver::CloseDriverHandle, valid handle ||
18:30:02 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
18:30:02 | CDriver::OpenDriverHandle, device: 212 ||
18:30:02 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
18:30:02 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
18:30:02 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
18:30:02 | CProductManager: Created ||
18:30:02 | CRegistry::Init - folder is empty. failed to init. ||
18:30:02 | CRegistry::GetCommonName(): AVG Secure Search ||
18:30:02 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
18:30:02 | CINIReader::Init - init: 1 ||
18:30:02 | CINIReader::GetText - start ||
18:30:02 | CINIReader::GetText - sSection: InstalledProducts ||
18:30:02 | CINIReader::GetText - sParamName: vToolbarUpdater ||
18:30:02 | CINIReader::GetText - result: 18.1.9 ||
18:30:02 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
18:30:02 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
18:30:02 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
18:30:02 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
18:30:02 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
18:30:02 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
18:30:02 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
18:30:02 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
18:30:02 | CRegistry::getValue(...), for key: CurCmpId ||
18:30:02 | CRegistry::getValue(...), QueryStringValue error: 2 ||
18:30:02 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
18:30:02 | CSystemCommands::GetUserID, (zstring) - start ||
18:30:02 | CSystemCommands::GetSafeEnv, (zstring) - start ||
18:30:02 | CSystemCommands::GetSafeEnv - (bool) - start ||
18:30:02 | CSystemCommands::GetSafeEnv, varName: appdata ||
18:30:02 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
18:30:02 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
18:30:02 | CBandToolBarCtrl::DownloadImages start ||
18:30:03 | CSystemCommands::GetSafeEnv - (bool) - start ||
18:30:03 | CSystemCommands::GetSafeEnv, varName: appdata ||
18:30:03 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
18:30:03 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
18:30:03 | CRegistry::getValue(...), for key: CurCmpId ||
18:30:03 | CRegistry::getValue(...), QueryStringValue error: 2 ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
18:30:03 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
18:30:03 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
18:30:03 | CSystemCommands::GetUserID, (zstring) - start ||
18:30:03 | CSystemCommands::GetSafeEnv, (zstring) - start ||
18:30:03 | CBandToolBarCtrl::DownloadFiles - Unlock ||
20:13:28 | CBandToolBarCtrl::DownloadFiles - Lock ||
20:13:28 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:13:28 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:13:28 | CDriver::OpenDriverHandle, device: 212 ||
20:13:28 | CDriver::CloseDriverHandle, device: 212 ||
20:13:28 | CDriver::CloseDriverHandle, valid handle ||
20:13:28 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
20:13:28 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
20:13:28 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:13:28 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
20:13:28 | CProductManager: Created ||
20:13:28 | CRegistry::Init - folder is empty. failed to init. ||
20:13:28 | CRegistry::GetCommonName(): AVG Secure Search ||
20:13:28 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:13:28 | CINIReader::Init - init: 1 ||
20:13:28 | CINIReader::GetText - start ||
20:13:28 | CINIReader::GetText - sSection: InstalledProducts ||
20:13:28 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:13:28 | CINIReader::GetText - result: 18.1.9 ||
20:13:28 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:13:29 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
20:13:29 | CRegistry::Init - folder is empty. failed to init. ||
20:13:29 | CRegistry::GetCommonName(): AVG Secure Search ||
20:13:29 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:13:29 | CINIReader::Init - init: 1 ||
20:13:29 | CINIReader::GetText - start ||
20:13:29 | CINIReader::GetText - sSection: InstalledProducts ||
20:13:29 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:13:29 | CINIReader::GetText - result: 18.1.9 ||
20:13:29 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:13:33 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:13:34 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
20:13:35 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:13:35 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:13:35 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:35 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:13:35 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:13:35 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
20:13:35 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:13:35 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:36 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:13:36 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
20:13:36 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
20:13:36 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:13:36 | CProductManager: Created ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:13:36 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
20:13:36 | CRegistry::getValue(...), for key: CurCmpId ||
20:13:36 | CRegistry::getValue(...), QueryStringValue error: 2 ||
20:13:36 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
20:13:36 | CSystemCommands::GetUserID, (zstring) - start ||
20:13:36 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:13:36 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:13:36 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:13:36 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:13:36 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:13:36 | CBandToolBarCtrl::DownloadImages start ||
20:13:37 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:13:37 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:13:37 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:13:37 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:13:37 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:13:37 | CRegistry::getValue(...), for key: CurCmpId ||
20:13:37 | CRegistry::getValue(...), QueryStringValue error: 2 ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:13:37 | CRegistry::GetPartnerName(): AVG SafeGuard toolbar ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:13:37 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar\Initialize\CONFIGXML ||
20:13:37 | CSystemCommands::GetUserID, (zstring) - start ||
20:13:37 | CBandToolBarCtrl::DownloadFiles - Unlock ||
20:22:21 | CSystemCommands::GetUserID, (zstring) - start ||
20:22:24 | CSystemCommands::GetSafeEnv, (zstring) - start ||
20:22:24 | CSystemCommands::GetSafeEnv - (bool) - start ||
20:22:24 | CSystemCommands::GetSafeEnv, varName: appdata ||
20:22:24 | CSystemCommands::GetSafeEnv, returns: : C:\Users\House Computer\AppData\Roaming ||
20:22:24 | CSystemCommands::GetUserID, returns: : 19355017207497b4 ||
20:22:24 | vprot.exe - _tWinMain, creating mutex.: Local\vprotector19355017207497b4 ||
20:22:24 | AVInfo: AVInfo C'tor, start ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2014 ||
20:22:24 | CRegistry::IsKeyExists(), Open error: 2 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2013 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg2012 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg10 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg9 ||
20:22:24 | CRegistry::Init - created path: Software\AVG\Avg8 ||
20:22:24 | CRegistry::Init - folder is empty. failed to init. ||
20:22:24 | CCrashReport::CCrashReport() no AV installed/AV version isn't 2014  ||
20:22:24 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:24 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
20:22:24 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:24 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:24 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
20:22:24 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:26 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:22:27 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/RegType ||
20:22:27 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:27 | CSystemCommands::GetXmlNodeValue - Unable to locate 'xmlnode' XML node ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/FileName ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/Type ||
20:22:27 | CSystemCommands::GetConfigurationValue sTagName: General/Product/BlockingInstalledProductTypes ||
20:22:27 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:22:27 | CProductManager: Created ||
20:22:27 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:22:27 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:28 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:22:28 | CINIReader::Init - init: 1 ||
20:22:28 | CINIReader::GetText - start ||
20:22:28 | CINIReader::GetText - sSection: InstalledProducts ||
20:22:28 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:22:28 | CINIReader::GetText - result: 18.1.9 ||
20:22:28 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:28 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:28 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
20:22:28 | CRegistry::Init - created path: SOFTWARE\AVG Security Toolbar ||
20:22:28 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:29 | CBandToolBarCtrl::DownloadFiles - Lock ||
20:22:29 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:29 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:22:30 | CDriver::OpenDriverHandle, device: 204 ||
20:22:30 | CDriver::CloseDriverHandle, device: 204 ||
20:22:30 | CDriver::CloseDriverHandle, valid handle ||
20:22:30 | CDriverHelper::WaitTillDriverIsRunning rc = : 1 ||
20:22:30 | ??????????????????: Ioctl = AA3F280B, ret = 1. GLE = 183 ||
20:22:30 | CSystemCommands::GetCommonFilePath - ProductName: vToolbarUpdater ||
20:22:30 | CSystemCommands::GetCommonFilePath - ProductVersion:  ||
20:22:30 | CProductManager: Created ||
20:22:30 | CRegistry::Init - folder is empty. failed to init. ||
20:22:30 | CRegistry::GetCommonName(): AVG Secure Search ||
20:22:30 | CINIReader::Init - path: C:\Program Files (x86)\Common Files\AVG Secure Search\InstalledProducts.ini ||
20:22:30 | CINIReader::Init - init: 1 ||
20:22:30 | CINIReader::GetText - start ||
20:22:30 | CINIReader::GetText - sSection: InstalledProducts ||
20:22:30 | CINIReader::GetText - sParamName: vToolbarUpdater ||
20:22:30 | CINIReader::GetText - result: 18.1.9 ||
20:22:30 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:31 | CSystemCommands::GetCommonFilePath - CommonFilePath: C:\Program Files (x86)\Common Files\AVG Secure Search\vToolbarUpdater\18.1.9\ ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - CoCreateInstance: 0 ||
20:22:31 | CRegistry::Init - created path: SOFTWARE\AVG SafeGuard toolbar ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - SelectToolbar: 0 ||
20:22:31 | CCoInitializer::~CCoInitializer() - calling CoUninitialize() ||
20:22:31 | CScriptHelperWrapper::CScriptHelperWrapper - folder: AVG SafeGuard toolbar ||
20:22:31 | CCoInitializer::CCoInitializer() - calling CoInitialize(NULL) ||
20:22:31 | CSystemCommands::GetConfigurationValue sConfigurationFilename: C:\Program Files (x86)\AVG SafeGuard toolbar\configuration.xml ||
20:22:31 | CSystemCommands::GetConfigurationValue sTagName: General/Product/TypeName ||
Message 4 of 24
laurenm9
I can download the program fine, but when it comes up to install I immediately get an error, here is the picture of the erro
Message 5 of 24
jessica.t
Sorry to say that your attachment is quite small / blurry and I cannot read it. If you could please reply with an attachment of your installation log file for further troubleshooting it would be very helpful. Thanks!
Jessica Thrasher
Message 6 of 24
laurenm9
2014/9/16:21:15:18 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_Architecture_2014_English_Win_32-64bit_dlm
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Launch
2014/9/16:21:15:18 House Computer HOUSECOMPUTER CommandLine
2014/9/16:21:15:18 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI9740.tmp
2014/9/16:21:21:23 House Computer HOUSECOMPUTER === Setup ended ===
2014/9/16:21:26:36 House Computer HOUSECOMPUTER === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Path_Length: 149
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Current Directory C:\Autodesk\Autodesk_Revit_Architecture_2014_English_Win_32-64bit_dlm
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Launch
2014/9/16:21:26:36 House Computer HOUSECOMPUTER CommandLine
2014/9/16:21:26:36 House Computer HOUSECOMPUTER Current Directory C:\Users\House Computer\AppData\Local\Temp\_AIF1ED.tmp
2014/9/16:21:26:48 House Computer HOUSECOMPUTER === Setup ended ===
here is the log
Message 7 of 24
laurenm9
the log will not post on this feed ive copied it in the reply and posted it many times and it keeps dissapearing
Message 8 of 24
laurenm9
Message 9 of 24
laurenm9
can i send you this via emial??? it will not post
Message 10 of 24
laurenm9
"2014/9/16:21:15:18    House Computer    HOUSECOMPUTER    === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/16:21:26:48    House Computer    HOUSECOMPUTER    === Setup ended ==="
Message 11 of 24
laurenm9
Message 12 of 24
jessica.t
Hi @laurenm9,
Could you try just copying the last paragraph? Have you tried posting it to a word document first and attaching that file?
Jessica Thrasher
Message 13 of 24
laurenm9
Hopefully this works as a word file!
Message 14 of 24
Following this as I'm having a similar issue installing Revit and can't seem to get anywhere with it...
Message 15 of 24
jessica.t
Hi @laurenm9,
The attachment worked but there isn't an error listed in what you've provided. Since we know a word document attachment works, please post the entire log. Thanks for hanging in there!
Jessica Thrasher
Message 16 of 24
laurenm9
That is the entire log for the installation... I will also attatch the toolbar log? thats the only other log that comes up.  I am also trying again to attatch the error message to you.  Maybe it does not show up in the log because it is not a download issue but an installation issue?
Message 17 of 24
ukdxb012
If you Select your start button and in the search field type in %TEMP% and select the <Enter> Key. (This will open the default Temp folder for this login).
There should be a log file in this folder with the words Revit in it. Can you attach that file.
Duncan Brannan
UK/EMEIA CAD Operations Manager
Twitter | LinkedIn
Message 18 of 24
laurenm9
2014/9/17:11:48:29    House Computer    HOUSECOMPUTER    === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:11:48:29    House Computer    HOUSECOMPUTER    Path_Length: 149
2014/9/17:11:48:29    House Computer    HOUSECOMPUTER    Current Directory C:\Program Files\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:11:48:29    House Computer    HOUSECOMPUTER    Launch
2014/9/17:11:48:29    House Computer    HOUSECOMPUTER    CommandLine
2014/9/17:11:48:30    House Computer    HOUSECOMPUTER    Path_Length: 149
2014/9/17:11:48:30    House Computer    HOUSECOMPUTER    Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI399.tmp
2014/9/17:12:02:39    House Computer    HOUSECOMPUTER    === Setup ended ===
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    Path_Length: 149
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    Launch
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    CommandLine
2014/9/17:14:20:25    House Computer    HOUSECOMPUTER    Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI18F0.tmp
2014/9/17:14:20:39    House Computer    HOUSECOMPUTER    === Setup ended ===
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    Path_Length: 149
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    Launch
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    CommandLine
2014/9/17:15:08:27    House Computer    HOUSECOMPUTER    Current Directory C:\Users\House Computer\AppData\Local\Temp\_AI1845.tmp
2014/9/17:15:08:35    House Computer    HOUSECOMPUTER    === Setup ended ===
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    === Setup started on HOUSECOMPUTER by House Computer ===
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    Path_Length: 149
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    Current Directory C:\Autodesk\Autodesk_Revit_2014_English_Win_32-64bit_dlm
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    Launch
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    CommandLine
2014/9/17:18:33:36    House Computer    HOUSECOMPUTER    Current Directory C:\Users\House Computer\AppData\Local\Temp\_AIE8B1.tmp
2014/9/17:18:44:29    House Computer    HOUSECOMPUTER    === Setup ended ===
Message 19 of 24
ukdxb012
What are you running to start the installer? Is it an exe in a Revit folder in c:\Autodesk\? Also, how big is the file?
You also said you deleted your temp folder, has it recreated the temp folder from where you deleted it?
My advice would to get a fresh download of Revit from the Virtual Agent... http://autodesk.creativevirtual15.com/autodesk/bot.html?isJSEnabled=1&businessArea=Root.Front%20Desk...
If you can, choose browser download.
Duncan Brannan
Twitter | LinkedIn
Message 20 of 24
laurenm9
in reply to: ukdxb012
I have tried brower download fromt he virtual agent twice with the same error when initialization comes up
Administrator Productivity
