Hi Eveyone,
I need to automate the installation of Autodesk VRED Professional 2014 SR1 instead of installing it manually. Please help me in creating silent installation and uninstallation package.
Vinod
Extract the installer. Then open a command prompt go to the folder.
cd to 'extracted' folder and type:
setup.exe /S /N YOUR_LICENSE_SERVER
Hi David,
Thank you very much for the solution.
I have followed the steps and able to install silently. But the application is installing the files in "C:\Program Files\Autodesk\VREDPro-6.6-x64" by default.
Is there any option or parameter to change the installation directory?? According to my requirement i need to install files in"C:\Program Files\Autodesk\VREDPro2014"
Vinod
I have tested and confirmed that the /D flag will not work. It will always install in the C:\Program Files.
