Installation & Licensing
How to install and uninstall Autodesk VRED Professional 2014 SR1 silently?
6 REPLIES 6
1214 Views, 6 Replies
Hi Eveyone,
I need to automate the installation of Autodesk VRED Professional 2014 SR1 instead of installing it manually. Please help me in creating silent installation and uninstallation package.
Vinod
6 REPLIES 6
david.lau
Extract the installer.  Then open a command prompt go to the folder.
cd to 'extracted' folder and type:
setup.exe /S /N YOUR_LICENSE_SERVER
David Lau
in reply to: david.lau
Hi David,
Thank you very much for the solution.
I have followed the steps and able to install silently. But the application is installing the files in "C:\Program Files\Autodesk\VREDPro-6.6-x64" by default.
Is there any option or parameter to change the installation directory?? According to my requirement i need to install files in"C:\Program Files\Autodesk\VREDPro2014"
Vinod
hashim.mundol
Please Try
/D CUSTOM_INSTALL_DIRECTORY
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
For more tips & tricks: http://upandready.typepad.com
Hashim Mundol
Autodesk Product Support
Autodesk, Inc.
in reply to: hashim.mundol
Hi Hashim,
It's not working as expected with /D. Still it's installing files in its default location.
I have tried as mentioned below
setup.exe /S /N YOUR_LICENSE_SERVER /D CUSTOM_INSTALL_DIRECTORY
Vinod
hashim.mundol
It might not implemented in the latest version.
I will need to run some tests.
For the Silent Uninstall please use
INSTALLDIR\uninstall.exe /S
Hashim Mundol
Autodesk, Inc.
david.lau
I have tested and confirmed that the /D flag will not work.  It will always install in the C:\Program Files.
David Lau
Administrator Productivity
