Hello.
When installator is computing required disc space the following error pops up:
Error 1606: Could not access network location bin.
I checked Windows help centre, my registry and all the shell's and things (registry) described there are ok.
I tried this with Maya 2011 x64 on my x64 system. Help anyone? This is f***** not cool...
Can you check out this post?
well yes I checked it, however it regards already installed maya,
"(replace the xxxxxxxxx with the path where Maya 2011 is installed)
msiexec /qb /X {887CB4A1-5DB4-4924-A2C6-CDCB72376CC7} INSTALLDIR=”xxxxxxxxx”
so what can I do? do the same thing for not-yet-installed maya making up the install directory? dunno :c
I was able to solve the problem with the following solution
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
