Installation & Licensing
Error 1606: Could not access network location bin.
3 REPLIES 3
tkpolak
5387 Views, 3 Replies
Hello.
When installator is computing required disc space the following error pops up:
I checked Windows help centre, my registry and all the shell's and things (registry) described there are ok.
I tried this with Maya 2011 x64 on my x64 system. Help anyone? This is f***** not cool...
3 REPLIES 3
david.lau
in reply to: tkpolak
tkpolak
in reply to: david.lau
well yes I checked it, however it regards already installed maya,
 "(replace the xxxxxxxxx with the path where Maya 2011 is installed)
msiexec /qb /X {887CB4A1-5DB4-4924-A2C6-CDCB72376CC7} INSTALLDIR=”xxxxxxxxx”
so what can I do? do the same thing for not-yet-installed maya making up the install directory? dunno :c
wppdev
I was able to solve the problem with the following solution
Resolution:-
The problem is due to a registry location pointing to a non-existent location for the user profile location.
Steps to resolve :
  • Go to run.
  • Type ‘regedit’ click ‘ok’. The Registry Editor window opens.
  • Follow the path given below.
  • [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Explorer\Shell Folders]
  • Check the location for “Common Documents”, It will be pointing to a non-existent location
  • Eg. "Common Documents"="C:\\Users\\Public\\Documents"
  • Change the value data of common document as:
  • "Common Documents"="d:\\Users\\Public\\Documents"  (or any valid location)
  • OR create that non-existent folder
  • Run setup again
Administrator Productivity
