I think the problem lies around here (pasted below) in the log.
Anyone has any idea why?
I have tried reinstalling it three times, same problem all the time.
Some kind of error happens during registering a dll.
I have also tried uninstalling Revit 2011 which I had installed and everything that uses autodesk shared libs, basically removed everything autodesk.
Please help!
MSI (s) (E4:60) [17:39:35:946]: Note: 1: 1722 2: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C 3: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\ 4: regsvr32.exe /s "RBCTMdbEditX.dll"
CustomAction win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C returned actual error code -1073740791 (note this may not be 100% accurate if translation happened inside sandbox)
MSI (s) (E4:60) [22:37:43:808]: Product: Revit Architecture 2013 - - Error 1722.There is a problem with this Windows Installer package. A program run as part of the setup did not finish as expected. Contact your support personnel or package vendor. Action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C, location: C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess\, command: regsvr32.exe /s "RBCTMdbEditX.dll"
Action ended 22:37:43: win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C. Return value 3.
Action ended 22:37:43: INSTALL. Return value 3.
In Windows Explorer navigate to the folder "C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAccess" select the file "RBCTMdbEditX.dll", right click and choose Rename. After renaming the file run setup for Revit 2013 again.
Danny
@DannyHubbard wrote:select the file "RBCTMdbEditX.dll", right click and choose Rename.
Thanks for the reply
What should I rename it to? anything?
Anyway I'll try rename it to RBCTMdbEditX.dll.bak and see what happens.
Unfortunately that didn't work...
still the same problem.
Is there any way that I can bypass the registration of this dll and manually register it at a later time?
Same problem here with Revit MEP 2013. Error 1722, action win64RegisterRBCTMdbEditX.742DD471_03BC_4C75_8992_518E2BDABD1C
Revit is installed, but It fail to start. I see the splash screen, then boom.
Lost one day with this. And this stupid installer detect that Revit MEP 2013 is installed, so I need to delete it, I'm not able to desinstall it with the control panel.
I've deleted the whole directory (C:\Program Files\Common Files\Autodesk Shared\Structural\COM\2013\DBAcces), relaunch the installed and It worked. 10 hours for installing a single program... I had to write a special program in order to remove some keys created in the registry by Revit...
Hi ,
I am experiencing the same kind of error for Revit Architecture 2012,i am unable reinstall the Application also.
Kindly help us to resolve it.
Operating system:Win7,64bit
Revit 2012,Network License.
Thank you in Advance,
D.M.Babu
