One of my autocad2013 user, every morning when he opens his autocad finds his all network support search paths are missing, while others having no problem at all, i am running out of options to fix this problem everyday, have any one out there got any clue about it, please help
Please check if you have licpath.lic file, first.
It should be stored in C:\Program Files\Autodesk\AutoCAD 2013
And check if it has appropriate information.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=2887766&linkID=9240617&siteID=123112
Please check this technical solution, as well.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?id=14374530&linkID=9240617&siteID=123112
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
The found the reason of off loading,
We don’t have instant connection to the network, as soon as we log in-after few minutes network drive become connected. So we need to confirm the availability of network drives before open the AutoCAD
The person used to face this problem he shut down his computer everyday instead of loging off like others.
