Custom Drawing Title Block
There should be an option to create custom drawing title blocks. I want to create a drawing but do not need all of the information shown in the current title block. There should be a way to at least select what information shows in the title block.
64 Comments
Hi there, All I ask for is something simple mainly because of my age so I need to be able to load a drawing sheet from an existing sheet which has the title block filled in with standard information applicable to the project I'm working with and then to fill in the variables and then populate the sheet with the part views to dimension. kind regards,
Geoff Wheeler
SimonHills
The new multisheet drawings offer exactly that. I am currently working on a project with 10+ sheets and All I have to change on each one is the title.
If you use a template from the start, this should be normal behaviour.
Hi there, Yes I accept this but it is getting the existing drawing sheet template into Fusion, I attach an empty drawing sheet to illustrate what I want to load into Fusion and then start adding views. The company details have been omitted at their request.kind regards,Geoff Wheeler
TimeraAutodesk
Status changed to: Gathering Support
Hi All,
We are beginning to work on how the first wave of release and revision management support in Drawings will function and feel like, so I wanted to follow up on this thread with the good news! If you would like to see more details, and be a part of providing early feedback, please see this post on the Feedback Hub.
Best,
Timera
