Creating a custom thread
visiontechmn
Message 1 of 28
visiontechmn
Hi Everyone,
I am trying to create a metric M82x.75 thread on a model.
How do you go about editing the pitch?
Thanks in advance
Replies (27)
Message 2 of 28
innovatenate
Autodesk Support
Autodesk Support
Welcome to the Fusion 360 Community!
If the thread size you are seeking is not avialable in the thread command, there's a tip in the below ideastation request that may help. If you edit the XML file you can make your own custom threads.
https://forums.autodesk.com/t5/ideastation-request-a-feature-or/custom-thread-pitches/idi-p/5392371
The other option would be to manually create the thread using the coil command or a series of other command like in the below post.
https://forums.autodesk.com/t5/design-validate-document/best-way-to-make-custom-threading-in-fusion/...
I hope this helps!
Nathan Chandler
Principal Specialist
Message 3 of 28
I'm running into trouble using the custom thread solution posted here: https://forums.autodesk.com/t5/ideastation-request-a-feature-or/custom-thread-pitches/idi-p/5392371
I created the custom xml file, but the custom thread data does not appear in the modeling environment.  Any ideas?
Message 4 of 28
HughesTooling
Just a thought, did you close and restart Fusion after making the custom file.
Mark
Edit also noticed there are no spaces in the file names of the standard files.
Mark Hughes
Owner, Hughes Tooling
Message 5 of 28
I tried both but no luck.  It seems that my thread menu only have five options, while the thread data file contains about fifteen.  A photo of the thread menu is attached.
Message 6 of 28
HughesTooling
This is one of those directories that changes with every update, I wonder if your Fusion is looking at an old directory. In the folder C:\Users\USERNAME\AppData\Local\Autodesk\webdeploy\production\ there are going to be several directories with numbers, one is the current one the others are old versions, I wonder if there's a directory in one of those that your Fusion is looking at.
Mark
Mark Hughes
Message 7 of 28
innovatenate
Autodesk Support
Autodesk Support
Have you modified the thread xml file? I'm seeing many more options. I've attached my threadData directory for review.
Nathan Chandler
Message 8 of 28
visiontechmn
I tried editing the xml file.......but no luck yet.
Message 9 of 28
innovatenate
Autodesk Support
Autodesk Support
I'm wondering if modifying the xml file (perhaps there's a typo somewhere) is what is casing the list to be shortened in the thread dialog.
Nathan Chandler
Message 10 of 28
innovatenate
Autodesk Support
Autodesk Support
Could you share the modified xml file?
Nathan Chandler
Message 11 of 28
Yes, that's what I would expect to see.  But I don't!
Message 12 of 28
Of course.  Thanks very much for the help.
This is the custom code I inserted.  The entire XML file is attached.
 <Designation>
       <ThreadDesignation>M58x1.0</ThreadDesignation>
      <CTD>M58x1.0</CTD>
      <Pitch>1.0</Pitch>
      <Thread>
        <Gender>external</Gender>
        <Class>6g</Class>
        <MajorDia>57.30</MajorDia>
        <PitchDia>56.485</PitchDia>
        <MinorDia>55.67</MinorDia>
      </Thread>
     </Designation>
Message 13 of 28
innovatenate
Autodesk Support
Autodesk Support
There was a space in front of the first of the text. To resolve the issue:
  1. I deleted this space in Notepad++
  2. Saved the CustomMetricThread.xml
  3. Closed Fusion 360
  4. Inserted the XML into %localappdata%\Autodesk\webdeploy\production\a7c43410973dfb12159f946aa55bfe5a9d8c57c4\Fusion\Server\Fusion\Configuration\ThreadData
  5. Launched Fusion and it seems to work
I've attached the edited XML file for reference.
Hope this helps!
Nathan Chandler
Message 14 of 28
Thank you!!  All that over a stupid spacebar.
Message 15 of 28
marius.chirita.uk
Where did my custom threads go ? Took me more than 2 days to make some custom threads and now they are gone. I think the software updates changed the paths or something happened. I can't find my custom threads in the Thread Type list.
Please help !
Message 16 of 28
HughesTooling
@marius.chirita.uk
When there's an update Fusion makes a new folder but doesn't move your custom thread XML files. You'll need to find the old folder with your threads and move them to the new location.
Mark
Mark Hughes
Message 17 of 28
sgsw_info
Observer
Observer
Checked all the above.
Have the same issue.
No matter what, if I add an xml file, all other threads disappear.
My path (Fusion at the last version):
C:\Users\biomushroom\AppData\Local\Autodesk\webdeploy\production\df2c2875432b4bd0d6eb31cb9221197ebfddc515\Fusion\Server\Fusion\Configuration\ThreadData
some ideas?
Message 18 of 28
Hi
I'm wondering if anyone can help me with a custom thread xml issue.
I've created the spec (xml attached) for a 49mm diameter thread with a pitch of 0.75mm - this is the standard for a photographic filter thread and can create a thread with this, however it will not model the thread, constantly giving the error 'failed to build thread tool'.
Is it my xml file or is there something else going on?  I am new to, and inexperienced in cad software.
Thanks in advance
Steve
Message 19 of 28
HughesTooling
@Anonymous Your sizes seem wrong. Below is a picture of your thread in an xml viewer and M9x0.75. Your threads should be pretty much the same numbers plus 40mm.
Mark
Mark Hughes
Message 20 of 28
Thank you Mark, I followed your suggestions and that's fixed it.
Steve
