Robert - There is no specific limit for the number of JPGs, but you may be
running into a file-size limitation. Could you send me the file with 10
JPGs in it so that I may try to add an additional one?
Also, can you tell me about your computer:
OS
RAM
IE version
version of DWF Composer
thanks!
Susan Scott
Autodesk Viewers QA
"RobertoD" wrote in message
news:22388433.1090362371818.JavaMail.javamailuser@localhost...
> Hello, I have added up to 10 jpg files to a dwf composer document, when I
try to add the 11th file, the application closes. Is there a limit on these
type of files or am I doing something wrong. Tried both dragging and
dropping and also from the open menu.
> Thank You
