From E-Specs website:
"As you enter text, keynotes, blocks, hatches, or other drawing elements,
your specifications stay in sync, in real time. Insert a wall, door, window,
or any other building object into your drawing and instantly update your
project manual with the appropriate specifications."
For AutoCAD, they allow you to create a mapping between names of blocks,
hatches, text to spec sections. Ex: if it finds "Ar-Brstd" hatch pattern
then it adds a section for Brick Masonry Units.
For ADT, they look at our objects, materials, and keynotes.
For both applications the specs are automatically kept in sync by reading
the .dwg's themselves.
chris yanchar | product designer
building solutions division | autodesk, inc.
http://autodesk.blogs.com/between_the_walls/
"Scott Davis"
wrote in message
news:409bcc97$1_3@newsprd01...
> How does E-spec work with AutoCAD/ADT? Does it read the drawings
directly?
> I thought you at least exported out a list/text file that E-specs reads to
> get the info.
> Just answered my own question on their web site. It scans the drawing
> files. I would think now that DWFs contain xdata, that a DWF could be
> scanned in the same way?
> I like the Revit solution for E-spec. Export to an ODBC database, and
> e-spec reads the database. This way, I can export my model to the
database
> and give it to the spec writer without gibing access to the model.
> SD
> "AlmightySR" wrote in message
> news:409bb36f_3@newsprd01...
> > Is there anything like E-Spec for DWF? I dont want the Spec writters to
> > have the access to raw DWG files...?
