Have you tried switching off the Auto Update through the registry?
Also, if the other issue is limited to one PC I would recommend taking all
the DWF apps off and then reinstalling ADR alone.
wrote in message news:5518304@discussion.autodesk.com...
...even after applying SP1.
Basically we had DWF Viewer installed previously...uninstalled, rebooted,
installed Design Review and then ran the SP1 update. Install and update
work fine. However, when opening Design Review, it says "An Update is
Available". Downloading the update (again) and installing doesn't fix it,
that pops up everytime.
The issue we're having is this one workstation is cutting off the top right
corner of DWFs. We have looked at the print options and we are using the
exact same options as other workstations, which print fine (same DWF too).
We tried the "Clip Pages" option, but it'll either clip the top right or
bottom right.
Thinking the SP1 update isn't taking, but not sure why. Thanks in advance
for the help.
BFC
