More bugs and more time wasted
yoshimitsuspeed
Advisor Advisor
Message 1 of 22
yoshimitsuspeed
So now I can't even associate drawings to center points of lines. This is another very frustrating step backwards.
Devs say they are putting a huge focus on drawings due to demand but it looks to me like it's not a priority at all.
We have simulation before half capable drawing or sketch capabilities? Are you kidding?
Dimensioning just to points just isn't a smart solution. Eliminating the ability to select center points is rediculous.
In sketches we can dimension to lines. Why isn't it the same in drawings? You guys still haven't addressed this issue and it has been brought up many times for a long time.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/aligned-dimension-doesn-t-work-right/...
If you can't be bothered to impliment GD&T as promised a long time ago at least impliment basic dimensioning that works properly.
Next big issue today. Creating tangency between an arc and a line. Not only is it possible for the tangency to invert but today out of 100 tries it probably inverted 95 times. Some times after a constraint had already been placed that prevents you from moving it back to how it's supposed to be. An example is if you are trying to make a slot. Instead it will give you something like the attached image.
Now it's frustrating enough when it inverts the tangent sometimes but when it does it almost every time it is just too much.
I have also lost a good bit of time today on a file that says it can't be moved because it is in use.
I opened and closed the file a number of times and even restarted F360 and it still said it was in use.
About an hour later it finally was able to be moved.
https://www.facebook.com/groups/1229995573786339/
Replies (21)
Message 21 of 22
TrippyLighting
My iMac is from mid 2010 and will have to last for few more years. So far I am very happy with it. Fusion has gotten al lot less crashy since Nov last year.
I believe some of the crashes I have are related to graphics hardware/drivers issues but they are really infrequent.
But then I only get to work with Fusion at night for 2-4 hours and don't use it all day every day. I also have to split my time between designing and building the electronics for my projects and progamming the stuff.
Message 22 of 22
O.Tan
Yeah, it's not as bad as before where common command operation crashes Fusion, there's still crashing bugs here and there but much less then a year ago.
I use Fusion around 6 hours per day so seeing less crashes is great so hoping for more improvements in the coming year!
Omar Tan
Malaysia
Mac Pro (Late 2013) | 3.7 GHz Quad-Core Intel Xeon E5 | 12GB 1.8 GHz DDR3 ECC | Dual 2GB AMD FirePro D300
MacBook Pro 15" (Late 2016) | 2.6 GHz Quad-Core Intel Core i7 | 16GB 2.1 GHz LPDDR3 | 4GB AMD RadeonPro 460
macOS Sierra, Windows 10
