Aligned dimension needs to be able to align to a point and a line and or two lines.
As you can see in the attached PDF I cannot properly dimension the distance between the two lines because I can only select points. The closest I can get on this drawing is by selecting the two centerpoints but this dimension is not alinged to the lines I am trying to dimension.
