Civil 3D Forum
Setting Default Label Style- Civil 3d 2013
4 REPLIES 4
6377 Views, 4 Replies
I am attempting to label top and bottom curb in my civil drawing.  I created a new label style in toolspace under points label styles. I created it with an expression to show a 6" curb.
My new label look like this in the label style composer.
TC: 100.00
BC:  99.50
However, I'm unsure where to set it as the default label style when I start labeling top and bottom of curb.   At this time when I use the label spot elevation command I still get the default single line like shown below.
100.00
Any help would be appreciated.
4 REPLIES 4
Jay_B
Set the default here:
Settings Tab of Toolspace> Surface>Commands>AddSurfSpotElevLabel>Default Styles>Surface Spot Elevation Label Style>
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
Jay_B
So is this a Surface Spot Elevation or are you creating Points and using a Point label?
C3D 2018.1
C3D 2016 SP4
in reply to: Jay_B
Spoiler
Thanks, I was creating my label in the point label style instead of the spot elevation label style.  Figured it out.
Spoiler
Spoiler
Thank You
jeffhdr
in reply to: Jay_B
Is there ANYWAY to do this at the command line? Trying to set the defaults thru LISP, or a tool Palette ahead of clicking on the ADDNOTE command.......
Rail Community
