Go to the upper left corner of the dialog and pick Action. You can clear the window from there.
Mr. Corey,
Regarding this post (long error list when rebuilding corridor) I'm trying to find a way to set the default error list in Event Viewer to show only the errors, not the information or warning items. I've been going in and filtering down to only the errors, which usually are not present, and noticed a "restore defaults" button in the dialogue. This tells me there is a place to SET the defaults. You know where this would be?
It's probably set in the Registry.
