Civil 3D Forum
Save window not showing up
42 REPLIES 42
Message 1 of 43
TTamburri
165774 Views, 42 Replies
So when ever I save something I get the file path and information coming up in the command bar but I am no longer getting the extra window showing up on the screen. I was wondering if anyone has come across this before and if you now how to fix it?
Tags (1)
42 REPLIES 42
Message 2 of 43
SethHall
in reply to: TTamburri
Hi tbyrne-
Try FILEDIA and setting it to <1>. This should allow your save dialog to display again.
Hope this helps!
Seth Hall
Product Owner
Model Builder
Message 3 of 43
TTamburri
in reply to: SethHall
Thanks so much.
Message 4 of 43
Yea, just had the same thing here on 2011, and also some day ago on 2010. Why does it happen anyway I didn't touch a thing 😛
Message 5 of 43
If you are using lisp routines, you might have one that sets filedia off and doesn't restore it if the routine fails for some reason.
Message 6 of 43
very very thanx
Message 7 of 43
It Worked. Great!!!
Message 8 of 43
Thank you!!!
Message 9 of 43
fguzma4
Thanks, it works. I am using autocad Electrical 2015. Thanks so much!
Message 10 of 43
My FILEDIA setting is already set to <1> and is still not showing the save window after pressing <OK> in plot window. What other possible solutions might there be? I am using AutoCAD Plant 3D 2017.
Tags (1)
Message 11 of 43
thanks folks!
Message 12 of 43
thank you so much i fixed it
Message 13 of 43
Thank you
Message 14 of 43
Thank you so much ! i had the same problem and it worked.
Message 15 of 43
genius !!! well done
Message 16 of 43
Mine just did the same thing... Fix worked great!  Thanks!
Message 17 of 43
Yes it worked for me
Message 18 of 43
thanks a lotWoman Very Happy
Message 19 of 43
thanks a lotttttttttttttttttttttttt
Message 20 of 43
Thanks a lot
Rail Community
