Civil 3D Forum
Joining roundabout corridors to main alignments
5 REPLIES 5
TOONFANCC
1264 Views, 5 Replies
I have created a roundabout and built corridors using the approach edge alignments. How do i tie these in to the corridors of my main alignments? I have attached images of the roundabout I have built so far and the approach and exit assemblies I have been using.
Any help/advice on building roundabouts would be gratefully received.
5 REPLIES 5
doni49
in reply to: TOONFANCC
Did you use the "Create Roundabout" tool?  Or did you create a corridor for the roundabout?
Don Ireland
Engineering Design Technician
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Please do not send a PM asking for assistance. That's what the forums are for. This allows everyone to benefit from the question asked and the answers given.
TOONFANCC
in reply to: doni49
I used the Create Roundabout wizard, and then created corridors using the approach edge and inner edge alignments it created.
You are going to need a bunch more assemblies to model it, use the large pieces you have currently and then build the other assemblies to model the holes.
dsimenic
I make corridor with multiple baselines and regions. Typically, one baseline is the ronudabout istself (radius - i prefer inner, small radii); others are edges of approaches.
MikeEvansUK
Work from the outside in with roundabouts.
You will need alignments as follows. Depends on your design standards of course these are for Brits but is stil a good method.
Roundabout crown line at 1/3 2/3rds.
Edge alignments following the entrances & exits created from entry to exit lanes for each junction.
centrelines for all junctions
See other post for more detailed description on modelling.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-General/Complex-Roundabout-Help/m-p/3752375/highlight...
Stockdale method; http://www.docstoc.com/docs/120766470/Roundabout-Design---Part-1.
Mike
Mike Evans
Civil3D 2022 English
Windows 7 Professional 64-bit
Intel(R) Core(TM) i7-3820 CPU @ 3.60GHz (8 CPUs), ~4.0GHz With 32768MB RAM, AMD FirePro V4900, Dedicated Memory: 984 MB, Shared Memory: 814 MB
Rail Community
