Civil 3D Forum
Project a Part (Pipe) on Section View
3 REPLIES 3
tonykhoury
2032 Views, 3 Replies
I have a pipe running parallel with a sample section.
There is a way to project that tipe on the section eventhough the pipe doesnt cross the section  ?
I did it on the profile view, by selecting the profile view, the i used the project part command. I can't find a way to do it on the section view.
Thank you
Tags (2)
3 REPLIES 3
Jay_B
in reply to: tonykhoury
Pipe Network Parts can't be projected in Profile or Section View, in Profile, I'm guessing you used the "Draw Parts in Profile" option.
  • You'll need a sample line at the pipe location.
  • Then the Pipe Network needs to either exist in the cross section dwg or be data referenced into it.
  • Sample Line Group Properties > Sections tab > Sample More Sources > Add the Pipe Network here and now it should display in section view, provided it crosses a sample line.
From the Help: Only the pipe network parts that cross the sample line are displayed in the section view.
Also From the Help: Pipe networks have a separate procedure for projection into profile views. See Displaying Pipe Networks in Profile Views and Displaying Pipe Networks in Section Views.
C3D 2018.1
C3D 2016 SP4
Win 7 Professional 64 Bit
tonykhoury
in reply to: Jay_B
Jay,
I posted this question before and i didnt get a good answer. Can you please help ?
I am having hard time to find a label table for the profile similar to the aligment label tablel. Does it exsit ? "
I want a dynamic table and not a table generated from the report, something like the table for the alignment .
Jay_B
I'm not aware of any option to create a "Profile Table" similar to an alignment table which will remain dynamic to changes to a profile.
The only options that I'm aware of are the information available in the Toolbox reports and the Profile Geometry Editor.
This information can be savead as xls (reports) or copy/pasted to Excel (from within the pfl geo editor) but it's not dynamic.
C3D 2018.1
C3D 2016 SP4
Rail Community
