Civil 3D Forum
Is autocad 2014 the same as autocad 2014
3 REPLIES 3
1094 Views, 3 Replies
Whenever I install Autocad Civil 2014 and open the program autocad 2014 opens.Whenever I search for the program,its listed as Autocad Civil 3D as Autocad 2014.I dont understand whats happening,Autocad Civil is the only version of autocad on my pc.Please help!
3 REPLIES 3
rkmcswain
If you want to run Civil 3D, click the icon that says "Civil 3D 2014 Imperial (or Metric)"
MarySeufert
Welcome.
From Windows Start Menu, select All Programs ->Autodesk ->AutoCAD Civil 3D 2014 - Within this there should be multiple shortcuts to start Civil 3D (Imperial units, Metric Units or vanilla ACAD).
Copy the correct unit C3D shortcut to your prefered location and jump in. If the shortcuts are not there, your installation is incomplete, and you will need to either repair or uninstall/reinstall.
EXPERT ELITE MEMBER
neilyj666
You are essentially opening vanilla AutoCAD when using this shortcut. The shortcut doesn't load the required Civil dlls etc etc hence they are not available
neilyj (No connection with Autodesk other than using the products in the real world)
AEC Collection 2024 UKIE (mainly Civil 3D UKIE and IW)
Win 11 Pro x64, 1Tb Primary SSD, 1Tb Secondary SSD
64Gb RAM Intel(R) Xeon(R) W-11855M CPU @ 3.2GHz
NVIDIA RTX A5000 16Gb, Dual 27" Monitor, Dell Inspiron 7760
Rail Community
