Whenever I install Autocad Civil 2014 and open the program autocad 2014 opens.Whenever I search for the program,its listed as Autocad Civil 3D as Autocad 2014.I dont understand whats happening,Autocad Civil is the only version of autocad on my pc.Please help!
Solved by rkmcswain. Go to Solution.
Welcome.
From Windows Start Menu, select All Programs ->Autodesk ->AutoCAD Civil 3D 2014 - Within this there should be multiple shortcuts to start Civil 3D (Imperial units, Metric Units or vanilla ACAD).
Copy the correct unit C3D shortcut to your prefered location and jump in. If the shortcuts are not there, your installation is incomplete, and you will need to either repair or uninstall/reinstall.
