Solved by JamesMaeding. Go to Solution.
I'm replying to this to see if there are any new answers. The original question was posted in 2007.
I'm working with C3D 2010 and synchronizing references when I open a drawing is bogging down my system and I can't open the file.
I've tried recover. It runs an audit, finds no errors, then starts synchronizing the references and I get nowhere.
The annoying part is that I don't need the references sychronized. I KNOW that they haven't changed since I saved. In fact, I don't even need them in the drawing. I needed them there earlier, but I don't need them there permanently. Now I can't even load this drawing as an xref in another drawing because it keeps getting stuck on synchronize. And I can't remove the references because I can't open the file.
Please, please, please... Somebody from Autodesk please address this!
Oh, and promote is useful in some situations. But that is NOT a good solution to this problem.
All I know is that this is total BS. I have asking Autodesk for the last 8 years to give us way to open these g.d. drawings without references, and they've never figured it out. I've been sitting here for 15 minutes waiting on a drawing THAT IS ON MY DESKTOP to open while trying to synchronize references.
FIGURE IT OUT.
I have the opposite problem, my drawing opens but won't synchronize a few of the data references until I manually sync them. This makes publishing an issue because when I publish, it opens the drawing from scratch (with unsynched data refs) and plots, but the end result has my profiles way off.
Any way to get it fully synched upon opening?
@Anonymous wrote:I have the opposite problem, my drawing opens but won't synchronize a few of the data references until I manually sync them. This makes publishing an issue because when I publish, it opens the drawing from scratch (with unsynched data refs) and plots, but the end result has my profiles way off.
Check this thread out.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D/Profiles-Not-Synchronizing-upon-Open/td-p/3667120
Don Ireland
Engineering Design Technician
Using C3D 2014 and I am running into this issue.
File xref management and Data shortcuts are being stored through a Projectwise enviroment to add to the complication.
I have multipule Data Shortcuts: surfaces, alignments and Pipe Networks that are being used to create profiles all which I know have not changed, and the drawing upon openning tries to synchronize all the data shortcuts as a result prevents the drawing from openning.
Has anyone identified a means of turning this off/on on startup?
Joe Bouza
the only way that i know of would be to rename the xref/shortcut drawing, and then when you want to resycn, rename the file back to the orginal.
The real problem here is Civil3D does not tell us what its doing.
I have run into this synch issue many times, and its usually because I got outsiders files and am trying to open them.
Then, sometimes I am troubleshooting stuff for a team that does not know how to solve things.
As a CAD manager, it is a scary thing to not have info on what a program is doing.
I think Autodesk should do some kind of diagnostic feedback mode that told us what was being looked for and other info too I could list.
This is a non-architectural change I would be asking for, but C3D development is not Autodesk's thing currently.
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Hi. Does anyone find a solution for this issue? I encounter the same problem. I created my alignments & profiles in a different file for designing, put it in data shortcut and use it in separate file for my drawing productions. I did some fancy daylight in the drawings using grading. Then I made adjustment to my original alignment. When I open my drawing, it will synchronize and then hang up. I can't open the drawing file now. I'm hoping to find solution here.
I'm running in to the same problem over here and found this thread. Feels like Autodesk is not fixing this anytime soon (which is absurd, given this is a massive hurdle). Basicaly, this prevents us from using D-ref's as synchronising xrefes clogs down our entire Drafting methodology.
we also have this problem. the only work around that I found was to copy the file to your desktop. disconnect that computer from the network then open up the drawing. this will open up the drawing with no xref's or dxref's. delete all dxref's then save (for us it is usually the surface). then reconnect the computer to the network and copy the file back to the server (as a precaution I always rename the original file something different). now when you open the drawing back up the xrefs are there but the deleted dxref's are not there. this is pain in the butt to do but if you have hours or days on a drawing it works.
Still here C3D 2018 drawing with pipe networks takes 30 mins to open sitting with Synchronizing files.
Cant find any reason for how long its taking... dwg is 18Mb and the xrefs are saved locally.
one drawing had 70,000 regapps in, these have been purged, saving and reopening doesn't speed it up.
I personally do not get why people use pipe networks. You can do all your design and production with alignments.
Any company that needed the 3d pipe could make a lisp to sample alignments at key points and 5 ft along to get a 3d pline, then run sweep to get the pipe. I did that long ago and never looked back. Then you can do hundreds of 3d pipes with perfect stability as nothing changes until you update it. Here is an example:
The little thin pipes are 4" drains. This is for a commercial site.
I've seen people use revit for full modeling as part of a BIM process, but they take weeks to do all that.
I did it in about 2 days once I had the cad files and plans, complete with hydrants and things we have lisps for also:
Do your business a favor and stick to alignments for utils.
Read this too: xyht Article
Interesting work around.
That may work for small networks, but the team have several networks that need clash detecting, parts catalogues accurate joints, etc... and all the other benefits that come from the network tools.
The main point of my reply was to show that The original issue posted in 2007 still doesn't have a resolution.
sitting there waiting for the system to do something doesn't help anyone.
