Hello
Good time.
How can the length of the excavation bed (CC), the length of the embankment bed (CF) and T1, as shown in the attached image, be displayed as a text or table in each cross section in Civil 3D?
please guide me.
Use MarkedPoint and LinktoMarkedPoint. Give a Link Code to the LinktoMarkedPoint. In your Code Set Styles, Links section, add the Link Code you assigned to the LinktoMarkedPoint and, to that, add a Label Style that includes a Component that uses LinkLength.
Respectfully, the truth is that you are not clear to me, please explain more clearly. The problem is that we do not know where the ground line intersects the surface of the datum, so that the point of length cc and cf can be obtained!
You're right. This is hard to explain without pictures. If you post your drawing, I can give you a video answer.
I want to help you and intend to help you, but now you're just being pushy. You want me to produce a video for you RIGHT NOW and you're not paying me to do it. Please, just chill out and I promise you'll get your video.
Hello
I tried to make the section close to your section
For CF wall length added, reduce if not needed
If there is a problem, we will solve it with the help of other friends
I'm very sorry. I did not mean that . Thank you for your kindness:cherry_blossom:🙏
I really did not understand the process.
You sent a file that added these items but did not explain how you did it. Give me a clue please!
Please guide me how you made this file with special assembly or special settings🙏.
I really need these sections in my project🙏
