Civil 3D Forum
Display of the length of the excavation bed and embankment in the section in Civil 3D
20 REPLIES 20
Message 1 of 21
Oliver_C3D
846 Views, 20 Replies
Hello
Good time.
How can the length of the excavation bed (CC), the length of the embankment bed (CF) and T1, as shown in the attached image, be displayed as a text or table in each cross section in Civil 3D?
please guide me.
Tags (1)
20 REPLIES 20
Message 2 of 21
tcorey
in reply to: Oliver_C3D
Use MarkedPoint and LinktoMarkedPoint. Give a Link Code to the LinktoMarkedPoint. In your Code Set Styles, Links section, add the Link Code you assigned to the LinktoMarkedPoint and, to that, add a Label Style that includes a Component that uses LinkLength.
Tim Corey
MicroCAD Training and Consulting, Inc.
Redding, CA
Autodesk Gold Reseller
New knowledge is the most valuable commodity on earth. -- Kurt Vonnegut
Message 3 of 21
Oliver_C3D
in reply to: tcorey
Respectfully, the truth is that you are not clear to me, please explain more clearly. The problem is that we do not know where the ground line intersects the surface of the datum, so that the point of length cc and cf can be obtained!
Message 4 of 21
tcorey
You're right. This is hard to explain without pictures. If you post your drawing, I can give you a video answer.
Tim Corey
Redding, CA
Message 5 of 21
Oliver_C3D
in reply to: tcorey
In my opinion, it is better to do the steps in video.
thank you
Message 6 of 21
Oliver_C3D
in reply to: tcorey
hello @tcorey
Good time
Regards "I'm waiting.🙏
Message 7 of 21
tcorey
I want to help you and intend to help you, but now you're just being pushy. You want me to produce a video for you RIGHT NOW and you're not paying me to do it. Please, just chill out and I promise you'll get your video.
Tim Corey
Redding, CA
Message 8 of 21
Ramin-AZ
Hello
I tried to make the section close to your section
For CF wall length added, reduce if not needed
If there is a problem, we will solve it with the help of other friends
Message 9 of 21
Oliver_C3D
in reply to: tcorey
I'm very sorry. I did not mean that . Thank you for your kindness:cherry_blossom:🙏
Message 10 of 21
Oliver_C3D
in reply to: Ramin-AZ
Hello @Ramin-AZ
Yes, exactly, I think you fully understand what I mean.
But this begs the question for me what (CF <L) and (CF> L) can mean. Thanks for the explanation!?
Message 11 of 21
Ramin-AZ
CF is divided into two parts based on height
Message 12 of 21
Oliver_C3D
Yes @Ramin-AZ
It is possible that you sent the Civil 3D file of my project, in which you ran this template. I want to check.
Message 13 of 21
Oliver_C3D
@Ramin-AZ
Have you done all this with Civil 3D? If yes, please help.
Message 14 of 21
Ramin-AZ
my friend
If your problem is solved
it is better to press the solved button
Thankful
Message 15 of 21
Oliver_C3D
I really did not understand the process.
You sent a file that added these items but did not explain how you did it. Give me a clue please!
Message 16 of 21
Oliver_C3D
in reply to: tcorey
Hello @tcorey
Good time.
Unfortunately, I have not reached a conclusion on this yet.
Thank you for your help.
Message 17 of 21
Please guide me how you made this file with special assembly or special settings🙏.
I really need these sections in my project🙏
Message 18 of 21
Message 19 of 21
send me file
Message 20 of 21
hello🙏
Rail Community
