Civil 3D Customization
Welcome to Autodesk’s AutoCAD Civil 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Civil 3D Customization topics.
Extract ground points section to model or file like land does.
25 REPLIES 25
Message 1 of 26
e_omairquliey
1011 Views, 25 Replies
Hallo guys i have problem that i can't extract the ground points section from civil 3d , i have searched the report section a lot of times and i couldn't extract them to model or file like land help me...
25 REPLIES 25
Message 2 of 26
Jeff_M
in reply to: e_omairquliey
You will need to be a little more specific. "Like Land" doesn't help much since I haven't used LDT in 14+ years. Are you wanting the EG along a profile or a section at specific stations, or ???? A sample of what you need would be helpful.
Message 3 of 26
e_omairquliey
in reply to: Jeff_M
Message 4 of 26
TerryDotson
If you were to consider third party add-ons, DotSoft's C3DTools will process an alignment, collecting points (optionally places CogoPoints) along the sample lines.  Exports station, offset, northing, easting and surface elevation at specified intervals (like -10,0,10) or all points where the sample line intersects the triangles of the surface.
Message 5 of 26
That mean i need to download that tool to get the points.
Message 6 of 26
hosneyalaa
Hi @e_omairquliey
Can you attached example drawing In which what You want
Message 7 of 26
welcome Hosneyalaa
Do you know how to use land desktop?
Message 8 of 26
e_omairquliey
in reply to: hosneyalaa
Do you know how to use land desktop, if yes i will give you the order that make the ground section sample so you can know what i need exactly.
Message 9 of 26
hosneyalaa
I was Use it a long time ago
no I remember What's your order
Message 10 of 26
this is the order in land desktop to import the ground points section to model.
Message 11 of 26
hosneyalaa
Ok ...
whats the result using this command Surely ...
there is something like it in civil 3d program But you need to export it to Excel then import pervaded
Message 12 of 26
that's great. so learn me how to import them to Exel from civil 3d.
Message 13 of 26
hosneyalaa
Message 14 of 26
Message 15 of 26
hosneyalaa
Message 16 of 26
e_omairquliey
Okay. i will send you an civil3d file.dwg there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
the project is ready to plot but the problem in how i could extract the points ground section like land.
Message 17 of 26
e_omairquliey
Okay. i will send you an civil3d  dwg file there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
Message 18 of 26
hosneyalaa
Message 19 of 26
He didn't extract the original ground point data to excel or model and didn't rap about this subject.
we are in Yemen attached with any design the ground points table for every station and those points most apply with the ground elevation and offset with appear in station section plot.
Message 20 of 26
hosneyalaa
try
Rail Community
