Hallo guys i have problem that i can't extract the ground points section from civil 3d , i have searched the report section a lot of times and i couldn't extract them to model or file like land help me...
Solved by hosneyalaa. Go to Solution.
Solved by TerryDotson. Go to Solution.
If you were to consider third party add-ons, DotSoft's C3DTools will process an alignment, collecting points (optionally places CogoPoints) along the sample lines. Exports station, offset, northing, easting and surface elevation at specified intervals (like -10,0,10) or all points where the sample line intersects the triangles of the surface.
Can you attached example drawing In which what You want
Do you know how to use land desktop, if yes i will give you the order that make the ground section sample so you can know what i need exactly.
this is the order in land desktop to import the ground points section to model.
Ok ...
whats the result using this command Surely ...
there is something like it in civil 3d program But you need to export it to Excel then import pervaded
Okay. i will send you an civil3d file.dwg there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
the project is ready to plot but the problem in how i could extract the points ground section like land.
Okay. i will send you an civil3d dwg file there is a project inside it. i need to extract the ground points which view in sample sections every 25 meters.
He didn't extract the original ground point data to excel or model and didn't rap about this subject.
we are in Yemen attached with any design the ground points table for every station and those points most apply with the ground elevation and offset with appear in station section plot.
