I am trying to convert my sketch file to dxf, however, some will not convert. r the program has an application-fatal error with program shutdown.
Any thoughts or could someone convert this SKF file. For reason I have tried to attach but it does not like the SKF extension
Bob Schatz
Wow, that's a lot of layers. I deleted every one that was turned off and it then saved as a DXF.
Let me know if you continue to have issues (I use AS10 in Win7 32 bit).
Steve thanks for the effort. Can you attach the file you converted. Also you mentioned you deleted some layers, can you convert with all the layers I supplied.
Thanks for the help!!
Bob Schatz
Airspace Specialist
Denver TRACON
It refuses to convert with most layers, so you have to keep deleting those layers that are turned off until it works.
Here's a DXF (2007) and DXF (R12)
