Hi board,
we are using autosketch 10 on different workstations, mostly Win7 32bit, but now also some Win7 64bit. We are currently facing the problem, that the thumbnail preview of skf-files only works in windows explorer, when we also install autosketch 8. But this method only works on our 32bit machines ... I installed two workstations with Win732bit, Autosketch 8&10 and no preview is visible, the explorer only shows a green skf-Icon.
Is there any solution or workaround available? Most of the users don't want to work with the internal preview.
Thanks in advance
Marcel
sorry, I made a mistake in my first post ... I meant to say "I installed two workstations with Win7 64bit, Autosketch 8&10 and no preview is visible ..."
To sum it up again - preview of skf works in Explorer only on Win7 32 bit (when I install both Autosketch 8 & 10)
Win7 64 bit only shows the green skf-icon (also with both versions installed).
