Hallo,
I have Autosketch 10 running on Windows 7 32bit. If I try to open the Symbolmager, this error message appears:
AutoSketch Executable
A Problem has prevented the right execution of the program. Close the program.
Then I can only close the program. In Windows Event Viewer I found these two events (sorry only in German):
First event:
Name der fehlerhaften Anwendung: Sketch.exe, Version: 10.0.0.11, Zeitstempel: 0x4935d148
Name des fehlerhaften Moduls: Sx2.dll, Version: 10.0.0.11, Zeitstempel: 0x4935d13c
Ausnahmecode: 0xc0000005
Fehleroffset: 0x00315814
ID des fehlerhaften Prozesses: 0x12a8
Startzeit der fehlerhaften Anwendung: 0x01cb80cefdcb0dfa
Pfad der fehlerhaften Anwendung: C:\Program Files\Autodesk\AutoSketch10\Sketch.exe
Pfad des fehlerhaften Moduls: C:\Program Files\Autodesk\AutoSketch10\Sx2.dll
Berichtskennung: 3f99271f-ecc2-11df-a43c-0024e8ec5866
Second event:
Name des fehlerhaften Moduls: ntdll.dll, Version: 6.1.7600.16559, Zeitstempel: 0x4ba9b21e
Ausnahmecode: 0xc0150010
Fehleroffset: 0x000817cf
Pfad des fehlerhaften Moduls: C:\Windows\SYSTEM32\ntdll.dll
Berichtskennung: 40b48655-ecc2-11df-a43c-0024e8ec5866
It seems that two dll-files sx2.dll and ntdll.dll are incorrect. I tried to start the program in Windows XP SP2 & SP3 compatibility mode with Administrator rights, but the result is the same.
Can anybody help me to solve this problem?
thanks in advance
Boran
Hi Boran
Its a lot of work but you could try uninstalling program and reloading the program , but instead of installing in the program files folder . try using the public folder instead. So its c:\public\autodesk... Then rt click on program shortcut and run in compability mode for xp. and also check disable desktop composition.
Regards
Jason
Dear Jason,
thank you for your answer. I have tried to fix the problem as you proposed. But the problem is still there. Any other idea?
Regards, Orhan
I'd try launching program as "Run as Administrator" . (Right click on AS icon). And make sure you are an admin when you do it. I case it is being denied access to some files.
Fred
Dear All, I still need help...
I have installed Service Pack 1 for Windows 7 Pro. The problem is still there. I can use the Symbol Manager, if I logged in as Administrator. But I cannot use it with my Account with Administrator privileges...
