IMPORTANT. Forum in Read Only mode. You can no longer submit new questions or replies. Please read this message for details
Autodesk Architectural Desktop 2007 & Prior
Welcome to Autodesk’s Autodesk Architectural Desktop 2007 & Prior Forums. Share your knowledge, ask questions, and explore popular Autodesk Architectural Desktop 2007 & Prior topics.
Dimensions don't add up
9 REPLIES 9
Message 1 of 10
1431 Views, 9 Replies
I have a drawing that has two strings of dimensions set at 1/16" precision.
The inner string adds up and displays a
different overall dimension when compared to the overall dimension string.
They are off by 1/8".
Any ideas
9 REPLIES 9
Message 2 of 10
Can you post a file
| Rob Starz
| Stardsign cad solutions
| AEC Designer / Consultant / Developer
| iC - AEC Information Center
| www.stardsign.com/aecic.html
| "can we make it any easier?!"
Message 3 of 10
It's due to the rounding.
Consider this simple addition: 7.8 + 4.7 + 3.6 = 16.1
Now round the display of every number to the nearest integer: 8 + 5 + 4 =
16 ??
Does that explain what's occurring? Switch your units to Engineering and 8
significant digits. You'll certainly see some dimensions that are NOT exact
16th's.
Bill Glennie
Autodesk Building Industry Division
Message 4 of 10
Which is one reason why you never close your dimension strings...
Message 5 of 10
and another reason for absolute accuracy when you're "just shoving walls around",
which is easier with a "nudge" routine (something familiar to former MAC cad
users) set to an exact unit such as 1/2".
I have one such routine for acad - created by some whizbang programmer over in
the customization NG a year or so back.
Message 6 of 10
then why not just use snap and set it at 1/2"?
Jack
"scott h" wrote in message
news:BCE5F3967DEF95CFB41FB4C4E5E8AD5A@in.WebX.maYIadrTaRb...
around",
cad
over in
Message 7 of 10
personally, I can't stand having snap set - because interferes w/ osnaps.
theoretically, this would solve the problem, though.... twelve ways to accomplish
anything w/ Autocad - none intuitive.
Message 8 of 10
Aw, it is not that bad. One thing I really like about AutoCAD is the
intuitive command abbreviations....L for line, E for erase, Z for Zoom, and
so on. I have a friend who tried to get me to use DataCAD. Talk about
perverse non-intuitive commands.
All I remember of it now is that to zoom I had to use a menu on the left and
it had a box with four icons around it and to zoom in or out you had to pick
the right one. To draw a line you had to go to a different menu and then to
another menu....Maybe I just don't remember it but it was way to difficult
for me.
Jack Talsky
news:947670CBE41A885236F680A25700ECF1@in.WebX.maYIadrTaRb...
accomplish
Message 9 of 10
well then, how about editing text or attributes? not too intuitive. after some
minor customization - sure... anyway, I don't wish to stray on a tangent.. it's
hard at first, but smooth sailing thereafter.
Message 10 of 10
Jerry:
Since Autodesk killed the flatland variable, it is also possible that you
have different Z axis point locations for your dimensions. I have noted this
happening more than one in my drawings.. even though I'm trying to force
everything to zero z. I finally created a toolbar macro that always gets the
xy0 of a point.
Craig
"Jerry Logan" wrote in message
news:61F022FE22E4FF62B669D483370A39FE@in.WebX.maYIadrTaRb...
precision.
> Any ideas
