I created a plate with 4 holes using the holes dialog option 2. Now I need to change the Hole diameter, but the bolts size remains the same. Can I edit this plate or do I have to delete the holes and bolts and start over? Hypothetcially could I also relocate these same holes if necessary?
Geoff
Solved by zcsillag. Go to Solution.
