How do I set ASD to stop generating bolt data on each detail. It is too cluttered with this unnecessary data. All I need to show are the hole locations and sizes.
If I ever did want to include bolts, how do I put the quantities in parenthesis, i.e. (1)3/4" bolt, rather than 13/4' as it appears now.
Geoff
Solved by zcsillag. Go to Solution.
So I have gone in and "drilled down" to the dialogue boxes which you have indicated in your screen shots, which contain the bolt descriptors %%Holenum%%Boltsign %%Boltlen. Am I supposed to delete this text? I would have thought that there would be an option to de-select a box indicating that you want the bolt information to be added to your Auto-generated Detail. I certainly do not see such an option, so is this the only solution?
Geoff
so made bolt description style *
and with description style template for assembly - templates use this description style
Thanks for the clarification. I had overlooked that the Style Name in your example was changed to a custom name.
Thanks again.
Geoff
