How do I select multiple items without having to hold down the shift key in ACLT 2013? I didn't have this problem in 2010.
Thanks for your help.
Solved by KateMorricalTowne. Go to Solution.
PICKADD set to 1 or 2?
PICKADD was set at 0. I get what I want with it set at 1. Interesting that the help says the initial value is 2 when my value was 0 coming from ACLT 2010.
Thank you for your help.
Most times these problems come from Variables that are set one way in one version and then are not set the same in another version. We get used to working the program one way and don't quite remember making the change or choice back at the beginning.
Saving your settings to Autodesk 360 should eliminate that issue for future upgrades.
Should it not? Like having profiles perhaps?
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
