can any one show me how to make a door on curved polyline plzzzzzzzzzz
Back in my construction days we framed the doors using two pieces of 3/4" plywood glued and screwed together. Drew the arc which was needed and cut. This was the rough opening for the bottom of the header. Then cut 3/8" deep curfs into 3/4" x 6" x rough opening lengths of plywood which we could bend for the header itself. Laminated these together by the glue and screw method mentioned above. Basically creating an engineered beam for the header which was the arc radius of the wall.
The doors could then be mounted into this rough opening. If you are using french doors as the picture depicts you might me using, the doors themselves would be straight. However, the jack studs, forming the rough opening inside the door opening, need to be cut with an angle along the height, this is to secure the doors to a flush and square surface, not a curved one. The king studs add to the door frame structure, so the little amount of material you remove from the jack studs will be negligible. See quick sketch attached.
EDIT: I might add that the entire section of the curved wall would have the sole plate and double top plate cut from plywood to form the necessary arc for framing the studs along its length.
Notice that your polyline is not planar.
