AutoCAD Forum
Delete ALL “drawing scales”,
51 REPLIES 51
Message 1 of 52
JamaL9722060
12842 Views, 51 Replies
I couldn’t figure out if there is a way to delete all “drawing scales” (attached) in one go. The delete should include all scales even those which are used in the drawing. One drawing scale is required to be kept which is 1:1.
Is that possible
Thank you
Best
Jamal
Jamal Numan
51 REPLIES 51
Message 2 of 52
rkmcswain
in reply to: JamaL9722060
Command:
-SCALELISTEDIT
Enter option [?/Add/Delete/Reset/Exit] <Add>: D
Enter scale name to delete or * to delete all unused scales: *
Enter option [?/Add/Delete/Reset/Exit] <Add>: E
Command:
; or using lisp
(vl-cmdf "-scalelistedit" "_D" "*" "_E")
 That won't delete scale list entries in use just like you can't purge layers or linetypes in use.
Message 3 of 52
JamaL9722060
in reply to: rkmcswain
Thank you very much rkmcswain for the help. This is very useful.
Is there a way to select objects that have a particular drawing scale? For example, how to select all objects that have the 1/200 drawing scale (attached)?
Jamal Numan
Message 4 of 52
if you set that scale current, then turn the light bulb next to the scale bar off, it will show ONLY the objects that have that scale associated (only objects active in the drawing).
Message 5 of 52
JamaL9722060
Thank you very much conormccartney3897 for the help
The issue here is that I need a lisp file that can do this in one go. This lisp file is supposed to do this automatically without the need to go through the scales one by one and delete them from objects (annotation objects) they are attached to. It is really long process if we delete the scales manually (attached).
Is that possible?
Jamal Numan
Message 6 of 52
Yes its possible, here's a quick lisp, it requires you to set the scale you want to keep, entered in the same format as it appears in the scale list, then deletes the extras. I cannot use a code block like normal, so this may be a little garbled. /p (defun c:scalereset (/ scl) (setq scl (getstring "/n Enter Annotation Scale:")) (command "cannoscale" scl "") (command "-scalelistedit" "d" "*" "e") (princ) )
Message 7 of 52
copy everything after the /p (i thought i rembered a work around) also this can be used with scriptpro to batch process, as you may need to run it on xref'd files as well.
Message 8 of 52
JamaL9722060
Thanks conormccartney3897 for the help,
Could you please integrate the code in one *.lisp file?
I have little experience in development
Jamal Numan
Message 9 of 52
um sure...ill have to do it later tonight at home, at work computer does not allow me to post things.
Message 10 of 52
JamaL9722060
Hi conormccartney3897,
Any update?
Jamal
Jamal Numan
Message 11 of 52
D'oh! Sorry bout that, I just set a reminder for myself to do this tonight.
Message 12 of 52
Bah. Sorry Jamal, apparently my reminder failed so try this instead, copy everything starting with (defun, in autocad, type VLIDE, this brings up the LISP interface. In a black file paste the code. you can change the command used by change what is after the "c:" statement. (defun c:scalereset (/ scl) (setq scl (getstring "/n Enter Annotation Scale:")) (command "cannoscale" scl "") (command "-scalelistedit" "d" "*" "e") (princ) )
Message 13 of 52
JamaL9722060
Many thanks conormccartney3897,
The *.lsp file works fine. It deletes all the annotation scales in one go (attached)
What should one type in the box of the “/n Enter Annotation Scale” (attached)?
Jamal Numan
Message 14 of 52
oh! enter in the desired scale to keep/set as current, needs to be entered in exactly as it appears in scale list. Also you can remove /n from the GETSTRING, appears we didn't need that.
Message 15 of 52
JamaL9722060
Thanks. That’s great.
Best
Jamal
Jamal Numan
Message 16 of 52
You're welcome.
Message 17 of 52
braudpat
Hello
I am not at all a Lisp/VLisp developper but the "international" routine would be >>
(defun c:ScaleReset (/ scl)
 (setq scl (getstring "Enter Annotation Scale: " ))
 (command "cannoscale" scl )
 (command  "_-scalelistedit" "_d" "*" "_e" )
 (princ)
The line:   (command "cannoscale" scl "")
generated an error but the routine was correct ...
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 18 of 52
WITHOUT USING LISP HOW WE CAN DELETE ANNOAUTO SCALE
Message 19 of 52
rkmcswain
See post #2 in this thread.
Message 20 of 52
JamaL9722060
in reply to: braudpat
Hi conormccartney3 and braudpat,
Is there a way to re-develop the lisp file (attached) to delete the ALL the annotation scales even the used ones (except the current)?
Jamal Numan
Forma Design Contest
