Hey guys. Sorry as this may be a newbie question but can't find any help online regarding this matter. I am using AUTOCAD 2014 and my tool palette is not visible. I have tried re-downloading it many times, resetting aplication options and resetting palettes. Still not working. Even my teachers at school can't seem to help. I am working on a 13' MacBook Pro late 2011 model running OS X 10.9.4 (13E28)
Many thanks
Solved by maxim_k. Go to Solution.
Hi Maxim thanks for replying.
Yes I have the full menu across the top of the screen but don't see the palette at all on the screen even though in the window tab it is ticked. Cmd+1 doesn't bring it up.
Thanks again
Ross
I did try this previously on another attempt when I wasn't getting the menu options either and it helped with that but no tool palettes still. I will try it again on this download and get back to you.
Ross
Hi Maxim
I have tried to reset yes and no joy. Also tried resetting palettes. If I select show as icons a thin strip appears on the left of the screen. Maybe 5mm wide. It looks like there is something off screen but have checked and nothing there.
Ross
As you can see there is a strip on the left buy nothing there when it's reduced. Also the tool palette is on.
Thank you so much Maxim
It worked perfectly, just in time too as i start mt course on monday. Keep up the good work.
Ross
