AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
copyclip problem
4 REPLIES 4
abm2k
2268 Views, 4 Replies
copyclip problem
hi,
when i use copyclip command & select object its take time for selection,
I mean when i select an object AutoCAD slows down sometime hang also
If I insert this file as xref to another file it takes time also.
If anyone knows the solution please please let me know.
Thanks in Advance
A.
4 REPLIES 4
maxim_k
in reply to: abm2k
It could depend on contents of your file, so without hawing it at hand it is difficult to say about the solution.
Check if you have:
- a lot of parametric constraints in your problem file,
- a lot of Layer groups (filters)
- try to use AUDIT command to fix errors in the file,
- try to use -WBLOCK command to write whole file to the disk as new file,
- check if you have Proxy objects created in AutoCAD verticals or third parity applications,
- etc...
If you can, you can post problem file here, I'll try to investigate
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
abm2k
in reply to: maxim_k
hi,
thanks for your reply.
I tried Audit & WBlock the whole file but it has the same problem.
so I am attaching this file for your investigation
A.
maxim_k
in reply to: abm2k
Your drawing was full of AcDgnLS proxy objects:
Simple -WBLOCK command with * option cleared them:
Command: -WBLOCK
Enter name of existing block or
[= (block=output file)/* (whole drawing)] <define new drawing>: *
Command:
See attached DWG. Does delays gone away on your side?
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
abm2k
hi,
Thank you very much Mr. Maxim
It's work the delays is gone
”Boost
