AutoCAD for Mac Forum
Welcome to Autodesk’s AutoCAD for Mac Forums. Share your knowledge, ask questions, and explore popular AutoCAD for Mac topics.
Rectangle Dimensions
3 REPLIES 3
1368 Views, 3 Replies
So I had a macbook and I installed autocad 2014 and my professor does tutorials on her windows but when she tells me to draw a rectangle and click command + D and i do it on the mac it doesn't work. she also gets like a text bar that says length and width with it (on her windows).
none of this seems to be working on my mac.
help??!
3 REPLIES 3
maxim_k
Welcome to the Autodesk Forums!
At first, could you clarify what do you want to do?
- Put dimensions of rectangle to the drawing?
- Just check information about dimensions?
If you need to check dimensions you need to use DIST command (just type D at the command prompt, hit Return and pick two points with object snap enabled to end point). Or you can use MEASUREGEOM command from here:
and get:
BTW: Ctrl+D on PC and Command+D combination on Mac - toggles Dunamic UCS ON and OFF.
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
in reply to: maxim_k
hi, thanks.
i'm just trying to set the dimensions of the rectangle aka (24'x16' and the
thickness of the wall to 1'6") however when i draw the rectangle and click
either ctrl D or command D nothing happens and it's super weird.
maxim_k
In order to set thickness of the rectangle you need to edit it's properties in Properties Palette:
or use commands for 3D object creation - EXTRUDE, PRESSPULL:
https://www.youtube.com/watch?v=YCiesi6Pxt4&list=PL8557ABB2A58DE382&index=6
Maxim
Maxim Kanaev
Architect
MARSS
MacACAD | Linkedin
”Boost
