By the way, the quantity column will only quantify all the doors which
have the exact same property sets. So, if you had a material property,
and one pocket door that was glass and another pocket door that was
wood, these would show on different lines on the schedule with different
quantities. If you want a different number, create two styles, one for
each material.
-Danny
Danny P. wrote:
> Actually the scheduling features of ADT were originally set up to work
> this way.
> Create a Property Set that applies to door styles.
> Create a Property called "Number" and make it auto-incrementing.
> Add the Property sets to the door styles in Style Manager.
> Create a schedule that applys to doors and includes a column for Door
> Styles: Number
> Add a quantity column for the Number.
> I'll post an ADT 2004 file in the Customer files under the same Subject
> line.
> Hope that helps,
> Danny Polkinhorn
> WATG
> Honolulu
> CMFG wrote:
>> --Is there a way to do a door schedule by styles rather than
>> individual door?
>> --To clarify: I want my door schedule to create a new door number
>> only when one or more of the property sets, classifications, or door
>> styles pertaining to a door are not defined by other doors in the
>> schedule. This would facilitate giving the same door number to
>> multiple doors that have matching schedule information, and cut down
>> on my schedule size.
>> --Does anyone have info on how to do this. If I need to create custom
>> tags, schedules, or formula properties -- I WILL DO IT. Help if you
>> can. --THANKS
