AutoCAD Forum
Conversion From .STP to .DWG
30 REPLIES 30
Message 1 of 31
183081 Views, 30 Replies
I was wondering if there is a way to convert files from .STP to .DWG on Autocad 2014? Or does the inclusive Inventor Fusion with the purches of Autocad have the conversion capabilities?
30 REPLIES 30
Message 21 of 31
JDMather
See attached dwg.
Message 22 of 31
in reply to: JDMather
This import type makes all object from the stp file into one object. Is there something that can be done to avoid that ?
Message 23 of 31
JDMather
Here it is as 3 parts.
Message 24 of 31
in reply to: pendean
I have AutoCAD 2013 for Mac and am having trouble opening an .stp file in CAD.  The file is 1.2MB. This is a 3D file, but I'm not sure I am in 3D model space.  This is my first time with 3D.  Any help is appreciated.
Message 25 of 31
HELLO,
AFTER COMPLETION OF IMPORT HOW TO OPEN THAT FILE ??
Message 26 of 31
makmak9
I have the same problem, My Autocad was unable to import .stp files.
Attached here are my files that cannot be imported in Autocad.
Tags (3)
Message 27 of 31
vmichl_cs
in reply to: makmak9
At least the 180F7003_A vert.stp file imported without problems into AutoCAD 2016 (Win64).
Vladimir Michl, www.cadstudio.cz www.cadforum.cz
Message 28 of 31
makmak9
in reply to: vmichl_cs
Why is it i am not able to import? I am using ACAD 2014 (64 bit)
Message 29 of 31
vmichl_cs
Now when we know the AutoCAD version you are using, I have retried the Import in AutoCAD 2014 and it also works fine. Using AutoCAD 2014 SP1 in Win7-64, the IMPORT command.
Message 30 of 31
i do that but it does'nt work...
what shout i do now????
Message 31 of 31
Alfred.NESWADBA
What is "that"?
Which messages do you see in the command-line as result of command start and messages from the program.
Some other questions which might help to answer them
  • which version of AutoCAD (and update/service pack) are you using
  • can you upload the STP file so we can try that file on our systems.
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2024
(not an Autodesk consultant)
Forma Design Contest
