Extrusion height of a 3D solid in Autocad 2011
10 REPLIES 10
Message 1 of 11
4254 Views, 10 Replies
Hello to all,
I use Autocad 2011 and i want to get the extrusion height of a 3D solid that is made with extrude command in the front view (in 2D not in 3D, like i make one rectangle in front view and i extrude this rectangle with any value of extrusion height. After this extrusion the extrude rectangle ramains in that position [in front view] in 2D not 3D)
Is this possible in Autocad 2011?
I try this way, but it did not work:
(setq ename-solid (car (entsel "\nSelect object: ")))
(setq vlaobject-solid (vlax-ename->vla-object ename-solid))
(vlax-get-property vlaobject-solid 'height) or (vlax-get-property vlaobject-solid 'extrusionheight)
What name of property can i put instead to the red word of this syntax (vlax-get-property vlaobject-solid 'height), that in final to get (to extract) the extrusion height of a solid?
In Autocad 2012 or greater is available this function with this syntax (getpropertyvalue object "property") (ex: getpropertyvalue (entlast) "height") but i want to get the same result in Autocad 2011.
Can anyone help me to find the way to obtain that result in Autocad 2011?
I want to thank all who try to help me in this problem.
Have a nice day!Smiley Happy
10 REPLIES 10
Message 2 of 11
Hallex
Hi marian, welcome on board
If solidtype is extrusion I would use code like this,
because of there is no vla-methods to calculate the height:
(setq solent (entsel "\nSelect solid : "))
(setq slist (entget (car solent)))
(setq extvector (cdr (assoc 10
			    (entget (cdr (assoc 360
								    (entget (cdr (assoc 350 slist))))))))))))
(setq extHeight (sqrt (apply '+(mapcar '* extvector extvector))))
(alert (vl-princ-to-string extHeight))
Message 3 of 11
in reply to: Hallex
Hallex thank you very much for your help!
You solve the problem very well and very quickly!
I am glad to be here and to see people who really want to help each other and to do good things.
I wish you all the best, and i want to know you that you make me very happy because you give me this solution. Smiley Happy
Have a nice night!
Message 4 of 11
Hallex
Marian, Glad I could help,
just a hint: try to set History in Properties to No or Yes
and try the same code again, I didnt test it
Cheers 🙂
Message 5 of 11
in reply to: Hallex
I tested your solution and it's ok.
It's just what i wanted.
You are the best! Smiley Happy
Thank you very very much!
Message 6 of 11
Kent1Cooper
Given the description as an extrusion of a rectangle, you could also get the object's bounding box:
  (vla-getboundingbox (vlax-ename->vla-object SolidEntityName) 'minpt 'maxpt)
  (setq
    LL (vlax-safearray->list minpt)
    UR (vlax-safearray->list maxpt)
and since the LL and UR are 3D points, calculate the difference in whichever is the appropriate coordinate for your use:
  (- (car UR) (car LL)) ; for the object's extent in the X direction
  (- (cadr UR) (cadr LL)) ; in the Y direction
  (- (caddr UR) (caddr LL)) ; in the Z direction
Kent Cooper, AIA
Message 7 of 11
in reply to: Kent1Cooper
Kent1Cooper thank you so much for your answer!
This is another good solution for my problem.
Thank you all!
Message 8 of 11
in reply to: Hallex
I need something similar that will work on multiple solids (box or extrusion) to make a list or table of all the solid heights.
This would be used to create a cut schedule of all metal tubes in a metal frame assembly.
Would this be posible?
Message 9 of 11
Please send me the extrusion lisp file..
Message 10 of 11
Hi everybody!
where is the complete lisp? can anybody upload it for common use
Message 11 of 11
could I get the lisp file for this or post it please?
Forma Design Contest
