Visual LISP, AutoLISP and General Customization
Extrusion height of a 3D solid in Autocad 2011
10 REPLIES 10
Message 1 of 11
marian.autocad
4011 Views, 10 Replies
Hello to all,
I use Autocad 2011 and i want to get the extrusion height of a 3D solid that is made with extrude command in the front view (in 2D not in 3D, like i make one rectangle in front view and i extrude this rectangle with any value of extrusion height. After this extrusion the extrude rectangle ramains in that position [in front view] in 2D not 3D)
Is this possible in Autocad 2011?
I try this way, but it did not work:
(setq ename-solid (car (entsel "\nSelect object: ")))
(setq vlaobject-solid (vlax-ename->vla-object ename-solid))
(vlax-get-property vlaobject-solid 'height) or (vlax-get-property vlaobject-solid 'extrusionheight)
What name of property can i put instead to the red word of this syntax (vlax-get-property vlaobject-solid 'height), that in final to get (to extract) the extrusion height of a solid?
In Autocad 2012 or greater is available this function with this syntax (getpropertyvalue object "property") (ex: getpropertyvalue (entlast) "height") but i want to get the same result in Autocad 2011.
Can anyone help me to find the way to obtain that result in Autocad 2011?
I want to thank all who try to help me in this problem.
Have a nice day!Smiley Happy
10 REPLIES 10
Message 2 of 11
Hallex
in reply to: marian.autocad
Hi marian, welcome on board
If solidtype is extrusion I would use code like this,
because of there is no vla-methods to calculate the height:
(setq solent (entsel "\nSelect solid : "))
(setq slist (entget (car solent)))
(setq extvector (cdr (assoc 10
			    (entget (cdr (assoc 360
								    (entget (cdr (assoc 350 slist))))))))))))
(setq extHeight (sqrt (apply '+(mapcar '* extvector extvector))))
(alert (vl-princ-to-string extHeight))
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 11
marian.autocad
in reply to: Hallex
Hallex thank you very much for your help!
You solve the problem very well and very quickly!
I am glad to be here and to see people who really want to help each other and to do good things.
I wish you all the best, and i want to know you that you make me very happy because you give me this solution. Smiley Happy
Have a nice night!
Message 4 of 11
Hallex
Marian, Glad I could help,
just a hint: try to set History in Properties to No or Yes
and try the same code again, I didnt test it
Cheers 🙂
Message 5 of 11
marian.autocad
in reply to: Hallex
I tested your solution and it's ok.
It's just what i wanted.
You are the best! Smiley Happy
Thank you very very much!
Message 6 of 11
Given the description as an extrusion of a rectangle, you could also get the object's bounding box:
  (vla-getboundingbox (vlax-ename->vla-object SolidEntityName) 'minpt 'maxpt)
  (setq
    LL (vlax-safearray->list minpt)
    UR (vlax-safearray->list maxpt)
and since the LL and UR are 3D points, calculate the difference in whichever is the appropriate coordinate for your use:
  (- (car UR) (car LL)) ; for the object's extent in the X direction
  (- (cadr UR) (cadr LL)) ; in the Y direction
  (- (caddr UR) (caddr LL)) ; in the Z direction
Kent Cooper, AIA
Message 7 of 11
Kent1Cooper thank you so much for your answer!
This is another good solution for my problem.
Thank you all!
Message 8 of 11
RenManZ
in reply to: Hallex
I need something similar that will work on multiple solids (box or extrusion) to make a list or table of all the solid heights.
This would be used to create a cut schedule of all metal tubes in a metal frame assembly.
Would this be posible?
Message 9 of 11
Please send me the extrusion lisp file..
Message 10 of 11
baliahmet
Hi everybody!
where is the complete lisp? can anybody upload it for common use
Message 11 of 11
edwarddabolt
in reply to: Kent1Cooper
could I get the lisp file for this or post it please?
”Boost
