I have an AutoLisp file that runs fine with AutoCAD Core Console 2013. It runs fine when loaded through the standard interface of 2014. However, it does NOT run using AutoCAD Core Console 2014. I know there are new security features in 2014. What has to be done to allow it to run in 2014 AutoCAD Core Console?
Randy
This post may be of use:
Cheers
"How we think determines what we do, and what we do determines what we get."
I figured it out. Your reply helped. Thank you.
In the SCR file, you have to add the first two lines before your load statement.
TRUSTEDPATHS
"path"
(load "file" nil)
"c:defunname"
Glad you found it useful, and thanks for posting your solution.
Cheers
